highlandjeeper Posted August 19, 2008 Share Posted August 19, 2008 I have installed RE 4.5" coils with 2" spacers. I have RESF adjustable UCAs and LCAs and I need to know where to set my lengths at. I used the numbers posted in another thread (LCA=17.25, UCA=15.5) and I have 10-11 degs of castor and pinion is approx 0 degs. Are these numbers just a basic guide? Do I have to just keep adjusting until I get the angles I need? Link to comment Share on other sites More sharing options...
89eliminator Posted August 19, 2008 Share Posted August 19, 2008 i found that any of the measurements got me in the ballpark of where i should be. it just took some turns here and there to get it right. Link to comment Share on other sites More sharing options...
highlandjeeper Posted August 19, 2008 Author Share Posted August 19, 2008 I guess I will have to try that. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 19, 2008 Share Posted August 19, 2008 http://www.yuccaman.com/jeep/re_db.html#arms This gives you close approximations with DB's. But your right there with the Castor numbers. I like 10 but began the get some funky DS angles with any more than that. CW Link to comment Share on other sites More sharing options...
highlandjeeper Posted August 20, 2008 Author Share Posted August 20, 2008 I set my lengths as follows: LCA=17" UCA=16.25" Castor is now 5.5 degrees and pinion/ds angle is +/- 5 degrees. I should be able to road-test it tomorrow night if all goes well and see how things are and take it from there. Link to comment Share on other sites More sharing options...
pingpong Posted August 20, 2008 Share Posted August 20, 2008 I have personally found 7-8* to be best, but with a good alignment it shouldnt matter. The drive shaft angle would be what I was worried about, it will cause vibes. :brows: Link to comment Share on other sites More sharing options...
mjeff87 Posted August 20, 2008 Share Posted August 20, 2008 I have 10-11 degs of castor and pinion is approx 0 degs. Mine was not driveable (very far, anyway) with similar numbers when I lifted mine. Got 1/3 of the way home from Pat's house and had to stop and drop the front DS before it self destructed. I reset caster to about 6 degrees and it's been fine since. But that was with an AX5, front DS is about 4" shorter than an AX15 or AW4 rig. I might be able to get another degree or two of caster when I get the 4.0/AX15 in place. Jeff Link to comment Share on other sites More sharing options...
