Overheating Fixes
Back in the winter when I put a thermostat in because the PO wasn't running one and the truck wouldn't heat up and run like crap I put a 195* in and drilled a whole at the 12 o clock position only.
You guys think it makes a differnce I didn't put one at the 6 o clock position?
Nope. The factory t'stat only has the hole at 12:00
Well, then I'm oficially done replacing everything with the cooling system. I'm wiring up the electric fan this week to run on a switch.
  • Replies 52
So when it was running without a thermostat it wasnt overheating/running hot?
