chicofuentes0224 Posted August 4, 2008 Share Posted August 4, 2008 To please do me a favor and check the temp on the metal on the outside of their thermostat housing to see if my temp is close to correct. I'm talking about hitting the metal tube that goes into the rubber hose going back to the fire wall. TIA :cheers: Link to comment Share on other sites More sharing options...
BLHTAZ Posted August 4, 2008 Share Posted August 4, 2008 I'll check mine for you tomorrow as it has already cooled off tonight :cheers: Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted August 4, 2008 Author Share Posted August 4, 2008 Thanks Brent :cheers: Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 4, 2008 Share Posted August 4, 2008 201* with my laser thermo when my dash temp gauge is reading 210*. And I "calibrated" my laser thermo with a mercury thermometer in a pot of boiling water. :eek: Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted August 5, 2008 Author Share Posted August 5, 2008 Thanks Don :cheers: Link to comment Share on other sites More sharing options...
offroader461 Posted August 5, 2008 Share Posted August 5, 2008 201* with my laser thermo when my dash temp gauge is reading 210*. And I "calibrated" my laser thermo with a mercury thermometer in a pot of boiling water. :eek: Is that were the sender is for your guage in the dash...i have lazered mine near the thermostat and it read 200* but the dash was reading 205* b/c the sender is located at the back of the head and not in the thermo-housing Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 5, 2008 Share Posted August 5, 2008 201* with my laser thermo when my dash temp gauge is reading 210*. And I "calibrated" my laser thermo with a mercury thermometer in a pot of boiling water. :eek: Is that were the sender is for your guage in the dash...i have lazered mine near the thermostat and it read 200* but the dash was reading 205* b/c the sender is located at the back of the head and not in the thermo-housing This was my reading at the stat housing as Chico asked for. My laser reading at the gauge sender was a bit lower, 198*. Next time I have my cluster out I'm going to calibrate my temp gauge. :D Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted August 5, 2008 Author Share Posted August 5, 2008 Well my thermostat housing is once again reading 214-219 so I guess I'm either running hot again or another laser thermometer is worthless. :wall: Link to comment Share on other sites More sharing options...
BLHTAZ Posted August 5, 2008 Share Posted August 5, 2008 OK...here is mine. The reading at the t-stat housing location as asked for was 198. The reading at the temp sender in the rear of the head was 215. The guage showed dead on 210 after driving 16 miles with the AC on Max and the outside temp at 94. My Fuji FinePix S700 :brows: took this pic less than one minute after shutting the engine off. Link to comment Share on other sites More sharing options...
