pantera1973 Posted July 31, 2008 Posted July 31, 2008 I'm considering getting an MJ that has later model Grand Cherokee seats in it. I know the Grand seats are a bit larger than regular MJ buckets, has anyone here ever been in one with Grand seats? If so how much difference was there in overall head & leg room? Thanks in advance. :wavey:
BLHTAZ Posted July 31, 2008 Posted July 31, 2008 I have not been in one, but I have read about the use of them in a couple different places and they said leg room was not a problem, but head room was lost. I believe they said 1-2".
Pete M Posted July 31, 2008 Posted July 31, 2008 It's not a typical swap, so I have to imagine it all depends on how the install was completed. You might need to sit in it to know for sure.
pantera1973 Posted July 31, 2008 Author Posted July 31, 2008 It's not a typical swap, so I have to imagine it all depends on how the install was completed. You might need to sit in it to know for sure. Yeah, I know that's the best way, but unfortunately the MJ is located about 3 hours away I do know he used the bench seat mounting brackets & the seats "bolted in".
Pete M Posted July 31, 2008 Posted July 31, 2008 I wouldn't worry too much about it. They can easily be swapped out for a different set of seats or adjusted (with some fab work) if they aren't quite right for you.
