james750 Posted July 15, 2008 Posted July 15, 2008 I just went to install my swaybar discos today and the driver side one plugged in right away but on the passenger side one there is not enough space between the trac bar mount and the swaybar mount post for the swaybar arm to slide on (hope this makes sense). any suggestions? TIA pics to come...
Motion Offroad Posted July 15, 2008 Posted July 15, 2008 Is the "post" pointing inward (away from the tire) or outward (towards the tire)?
james750 Posted July 15, 2008 Author Posted July 15, 2008 Is the "post" pointing inward (away from the tire) or outward (towards the tire)? Away from the tire (inward), the post just replaces the lower trac bar mounting bolt.
SuperWade2 Posted July 15, 2008 Posted July 15, 2008 I just went to install my swaybar discos today and the driver side one plugged in right away but on the passenger side one there is not enough space between the trac bar mount and the swaybar mount post for the swaybar arm to slide on (hope this makes sense). any suggestions? TIA pics to come... Something like this... I beat the crap out of mine and it barely went on... I had to bend the Pin and the mount just a little bit each to get it even on there... don't know if it's gonna gone off "easily" or not...
SuperWade2 Posted July 15, 2008 Posted July 15, 2008 thats my exact problem wish I had a good answer for you..i just pounded on mine
james750 Posted July 15, 2008 Author Posted July 15, 2008 Ive been thinking. I could make a bracket that puts the swaybar mount out farther therefore moving the post out of the way. ill photochop something up.
offroader461 Posted July 15, 2008 Posted July 15, 2008 on my JKS i think that my pin faces the other way so that i don't have the "interference" issue with the trackbar bracket
james750 Posted July 17, 2008 Author Posted July 17, 2008 there isnt enough side to side movement in the bracket to mount the post on the other side, though i do think it is that way on TJ's. I'm sure that there is a simple way to fix this. maybe ill try posting it on the JF XJ section.
Motion Offroad Posted July 17, 2008 Posted July 17, 2008 The problem is with the amount of lift your running with your stock steering setup. The higher the lift you go, the more you move your stock steering up and in the way. Your changing the angle of the draglink; thus putting it in the way of the disco. The only real solution (without going with a different steering setup) is to make a bracket like you mentioned above to raise the mount. This is why the RE Gen. 2 swaybar quick disco's mount the pin pointing outward towards the tire on that side. This is also why a lot of the aftermarket steering setups require you to re-located your swaybar mounts as they get in the way.
SuperWade2 Posted July 17, 2008 Posted July 17, 2008 The problem is with the amount of lift your running with your stock steering setup. The higher the lift you go, the more you move your stock steering up and in the way. Your changing the angle of the draglink; thus putting it in the way of the disco. The only real solution (without going with a different steering setup) is to make a bracket like you mentioned above to raise the mount. This is why the RE Gen. 2 swaybar quick disco's mount the pin pointing outward towards the tire on that side. This is also why a lot of the aftermarket steering setups require you to re-located your swaybar mounts as they get in the way. Got the SAME problem with less than 2" of lift...I got mine on, but not sure they are getting disconnected without removing the pin... Unless I'm remebering it wrong (and I'm not under the truck now), it's not even close to the draglink end at all, it's the lower TracBar mounting bracket on the axle that will be in the same place no matter what steering is on there. SW2
james750 Posted July 17, 2008 Author Posted July 17, 2008 SW2, yes that is what the problem seems to be I'm running about 2-3" max and it won't work there. that bracket as mentioned above could also be pointing downward and below the trac bar mound therefore being out of the way. But I would have to reposition it when I upgrade the lift to a 6.5 longarm.
offroader461 Posted July 17, 2008 Posted July 17, 2008 your right...i was away from the MJ and assumed they were that way...mine are the same direction as yours but i didnt have a problem when i put mine on
