sounds like im dragging cylinders
hey guys, ive tried everything i can think of and I'm out of ideas. my 88 2.5 comanche is idling really rough and when you give it full throttle it completly dies, but when you let off the throttle it comes back and idles like $#!& again. i replaced cap,rotor,wires and plugs. its also got brand new alt in it. only other thing i can think of is TPS or comp. anyone got any ideas?
Have you had the distributor loose or out recently? There have been a couple guys around here with similar issues and it was found to be the distributor was off by one tooth in both cases.
You also have a timing tensioner in your engine that the 4.0L's don't have that could be gone and allowing your timing to be thrown way out of wack.
no i havent had the dist out or loose at all. it almost seems to run ok at around 3-4 rpms but i can tell its still not right. i thought of that tensioner but was hoping not to have to pull the cover to check it
also it did this to me before awhile back. then it was cuz the alt was junk and when i floored it, it didnt have enough voltage to open the injector up so it bogged down like it is now. but its a brand new alt and when i disconnect the batt it still runs so thats not it this time. it just started happening again, i went out wheeling and it was running perfect, went to go hook up to pull my buddy and it started doing it again.
oh, and when i replaced the old cap and rotor, the rotor had somehow chewed into the cap pretty good. that mean anything?
Ummm, yeah. It likely means that your distributor is worn out, the shaft is wobbling around, and it's not properly keeping time. Sounds like you most likely need a new (or rebuilt) distributor.
Yep...exactly what Eagle said.
If you look in there now...you will probably see the same problem developing again ;) .
and it don't take much movement to comsume the inside of the cap :brows: look into getting that replaced and ensure when you do that the no. 1 piston is TDC. jamminz.gif
  • 4 weeks later...
