Everything posted by whatis42
I just got a unidin pc68 elite today at a local CB store. The guy in there sold me a noise canncling mic and a Wilson Little Wil magnetic antenna. Anyone ever had the problem of there magnet antenna walking off while your in a store? Also what do you guys think is the best way to get it's cord into the cab? Down around thogh the firewall?
As the title says starts then stops? I was going to try replacing the cps but I can't figure how to get to it! :mad: New wires plugs cap rotor.. New ceramic fuel pump ballast resistor [broke that the other day] I replaced brake mc and booster last night. ummm not sure what else well thanks....
Can I buy a diagnose tool for my 88 with a 4.0? If not does anyone have some flow charts for diagnosing problems with a voltmeter?
Two reasons for HD: Will be 4WD at some point, and on a daily basis I have about 700 pounds in the bed. on days like today I did multiple trips to A1 soil and put 1 yrd a time in. (7 yrds total) I guess what I'm trying to say is I should have bought a Dodge 2500 with a cumins. OO and i like to spend money!
wow maybe it is time to sleep jy not yj as in junk yard not wrangler..................................................................................................................
Ok so prices i see are... Currie: $359.95 Poison Spyder: $246.05 yes .05 JCR: $269.00 Rustys Offroad: $260.00 :???:
I need to repair/replace my tie rods ends and all that junk. So I'm woundering if i should just replace what needs it or opt for upgrading the steering to an HD type. If you vote for HD please recomend a brand you have used to or what ever. Thank you for playing the Steering poll game! .............. sorry the only prize for this game is shared knowledge. :thumbsup: P.S. I need some sleep.
mine came with one I probably should see how it's wired up huh? ;) Why have an on demand switch at all if you have it wired to the thermostat?
Another Suspension topic....
whatis42 replied to whatis42's topic in MJ Tech: Modification and Repairs
Components RE1141 ~ GEN2 DISCONNECTS 2"-3.5" TJ, RE1334 ~ COIL SPRING SPACERS 1.75" RE1345 ~ COIL SPRINGS XJ-5.5 / ZJ-4. RE1380 ~ BUMPSTOPS 2" FRONT LOWER RE1513 ~ BRAKE LINE SS REAR 22" RE1550 ~ BRAKE LINE SET SS FRONT 22" RE1660 ~ TRACK BAR, XJ/ZJ EXTREME-DUTY RE1665 ~ TRACK BAR BRACKET, HD XJ/ZJ RE1935 ~ SPRING PERCH STANDARD 2.5"/PA RE2025 ~ SHOCK MOUNTS, DROP, WELD-ON RE2055 ~ CJ/MJ/XJ/YJ HD SOA SPRING PLAT RE2120 ~ T-CASE LOWERING KIT XJ/ZJ 3/4" RE2421 ~ U-BOLT KIT M35 REAR, YJ / XJ RE3700 ~ CONTROL ARM SF2 LOWER FIXED RE3781 ~ CONTROL ARM SR2 UPPER FRONT FI RE9900 ~ XJ CONTROL ARM DROP BRACKETS RE9921 ~ SWAY BAR RELOCATION BRACKETS + 4x4groupbuy.com gives you 4 dt3000 shocks I opted for Rubicon shocks for $90 more. -
Thanks I'll try the green. Will there be any issues with my truck being 2 wheel drive? I know I won't be able to use some of the parts, but I'm wondering if there is anything else i need to get since it's a 2wd? Thanks. -
You guys know of a greese and grime cleaner for cars? I want to clean off my under side and make it purdy. Like a Fast Orange for cars! :brows: -
What is BP Blaster? There are a couple of hardware stores near by. Another friend will weld or he will make me do it..... -
A buddy of mine is coming in town next weekend to put a new motor in his VW Thing. I help him, he helps me with my truck, so its a perfect time to put a lift on. I'm planing on ordering the re 5.5 mj kit from 4x4groupbuy.com tomorrow. Also I will be calling Alcan for new rear springs. So my questions are: Anyone know how long Alcan normaly takes to make you a nice set of springs? I've heard people say the re kit is the most complete. So if it's the MOST complete whats it missing? Anything I should look out for my 1st time lifting a truck? Anything I should buy? I really want to do everything right so if I could use it but don't have to have it I want to buy it. This truck is my new baby. 8) Thanks in advance, Kendrick Now it's time to put my new TB on I got from Artsound on ebay...
ya I kinda jumped to conclusions, it was just that the po seemed shifty. I have not had a change to check it yet, I worked 11 hours to day so I'm tired. Thanks tomorrow after work I'll check those things. What could have caused it to over heat? Was it just this? thankss
I was on the freeway going up a med. grade. I started to loose power so I pulled over and then a lot of steam started to come out of the engine bay. So loss of power and coolant leak.......... head gasket? I'll pull the plugs to see if there is oil or water on them after I EAT... Any tips or ideas? Thanks, Kendrick
For you who don't like high flow exhaust. Do you think doing stock exhaust set up, but with a Flowmaster for the noise. Yes I'm young but hey I like it but I do not want to loose power. So just wondering what ya all think.
If you have win98SE and an Ethernet card or better.. (I.E. if you're computer runs ME, 2000, or XP) You can use DSL or cable. The main thing is the LAN card. Remember to watch out for the contracts with DSL and the changing rates of Cable after 3 months. If you go with cable buy a modem please don't pay $10+ a month for a rental. Have Fun!
I'm planing on doing this tomorrow if its not raining. What about the filter does that need to be replaced?
At NAPA you can get NAPA brand oil for $1.89 and NAPA Silver filter for $5. I get the napa gold filters ($6). I was told some where that napa brand oil is valvoline and the filters are Wix. I don't know if its true or not but it has worked great for me. A lot better then Mobil and fram. Man using a japanese keyboard is hard........
tail lights / brake lights
ok got it fixed. It was not what I thought. fiatslug87 was right. Thanks, Kendrick -
I went to lunch with a buddy to day and on the way home he noticed my brake lights were not working... any way. My brake lights do work sorta. When I step on the brake pedal the brake lights do not turn on, but when I turn my head lights / tail lights on, my tail lights and brake lights turn on and stay on. Any idea where I should look for the crossed wire/s? :nuts: Thanks, Kendrick
I just got my manche a few days ago, and since then I've been making plans for it like crazy! What I was wondering is if I went SOA with my NON-metric (as in not metric pack) rear leafs would it effect my payload ability? This is going to be a daily driver for me. Thanks Kendrick
This my new MJ that I just got a couple of days ago. It's gona be a lot of fun to build up. here's what it looks like for now.
Hello all, I've wanted a Comanche since I fell in love with jeeps. So it's time for me to get one, also i need to buy a truck so it works. I'm looking at a jeep up in LA so I wanted to find out if there is anything I should know about the 88 manche 4.0 auto long bed, common problems, etc. So I will :bowdown: to your :smart: and turn my :dunno: into :beerhead: but not while Thanks for any help.
