Everything posted by drcomanche
Adding A/C Technical Thread
drcomanche replied to drcomanche's topic in MJ Tech: Modification and Repairs
According to the Haynes manual(which I'm not sure how reliable it is) there are 3 wires going to the ECU from the HVAC harness. The power input is the Blue White wire to the 4 pin relay. The only one from the cab that interacts with the ECU is the white green wire that passes through, but before it gets there, it divides to the relay and the low pressure switch. Its inclusion in the relay is what dictates the compressor clutch engagement. The rest that connect with the ECU seem to feed out to the other components. I reiterate that the Haynes manual has wires that don't exist on any of my 3 harnesses(91, 93, 96) so this is what I've gleaned from looking at the physical harness and the diagram. I figure the only thing the compressor needs from the harness is a single signal for when the interior selectors choose AC to engage the clutch. I say all of this mostly in speculation, since I can't start my vehicle and volt check it. I'm trying to understand the wiring to the best of my ability, and this just seems to be the most likely solution. I'm open to broadening my scope with more info so that we can have the most complete manual for installation. -
Apparently, from what I've heard, newer age compressors don't draw as much power, so it doesn't need the extra idle rpms. I'm not sure how true that is, but it's something to consider. -
I've seen another plug with almost the exact same fitting type, so maybe that relates to the dealer installed side. It's a 2 pin connector with only a tiny difference in the internal shape. I'd be curious to see how the pre 91 harness looked. If you have some pics or more info on that, I can add it to the main post so we can compile everything. The best I can guess is that when the ac kicks on, it triggers an idle adjustment for the extra load. I'll have to ask a buddy who's more well versed in the programmed side if it does more. Judging by the system, it doesn't seem to need too much from the ECU. The rest of the wires that go through the block seem to go to the relay or the blower motor. Only the green wire hits the ECU. -
This will be a thread to compile all the information about adding AC to non AC equipped trucks. I know there is another thread started almost a decade ago, but it seems to have very little info on the subject. Eventually, this should turn into a write up to settle all of the questions and technical info into one place. If you feel like I've missed something or want more info on a specific application, I can try to look into it and figure it out as well. This is for all the information, so I will edit the original post as we go. For background, I have been taking apart a bunch of stuff on the truck(as per my usual winter tradition) and while I had the dash out I figured, why not add AC? It can't be that hard. In terms of mechanical difficulty, it isn't. The electrical became a huge issue, on the other hand. Anyone with enough mechanical skillset to remove their dash should't have too much issue installing this. Obviously, the easiest way to add AC is to get a system from a matching year donor vehicle, that was you won't have to troubleshoot wiring. I chose a 96 because it was available to me for cheap and it is an r134 system, making it easy to charge and deal with. The parts I grabbed from the donor were: Compressor Evaporator(the "radiator" in the HVAC box) Condenser(the "radiator" behind the grill) Drier Expansion Valve Suction Hose(Compressor to Valve) Discharge Hose(Compressor to Condenser) Liquid Hose(Drier to Condenser) Hose(Drier to Valve) Low pressure switch(attaches to Drier) HVAC airbox(AC equipped airbox assemblies came with a larger compartment space to fit the evaporator) Dash harness(My truck wasn't equipped for AC, so there were no wiring components in the harness) HVAC Controller(the in dash selectors) *These parts can change depending on what years you are scavenging parts from. I believe some systems had an accumulator, too. I took all of my parts from a 96 Cherokee. Installation of the engine bay components is fairly easy, using pre existing bolts and holes. Non AC equipped trucks will have to remove the dash and replace the internal airbox with an AC optioned one. If you're looking, I recommend going to a pull yard and taking the whole system, that way you know you have everything and know it all fits together. The wiring is the tough part of this one, so based on my experiences, I've created a few diagrams to help make it possible. The Haynes manual was of some help here, but it was lacking in some of the wiring bits, which makes it all the more confusing. The wiring itself is a small grouping. I chose to dismantle the entire harness to separate it as completely as possible rather than cutting and trying to build it. This involves removing a few pins from the firewall plug and one from the fuse block. The firewall plugs require you to remove the retaining pins before they can be removed(plastic bars on the side of the block). Then just use a 90 degree pick to work it out of the hole. The fuse block side has 2 metal prongs on either side holding it in. I used the pick for this as well, and with a little manipulation got it out. The rest of the circuit is attached only to these 4 wires. The black and tan wire is the power in and splits into 2 wires(also black and tan) that feed into the same plug, but 2 different switches. This feeds the sliding bar selector on the dash unit. From there, it has 2 light green and white wires that exit, one going to the firewall plug and turning into a green wire that feeds the low pressure switch, the AC relay, and the ECU while the other goes to the thermostat plug attached to the HVAC box in the cab. The last wire(yellow tan) goes to two different locations, the first being the blower motor selector switch on the dash unit, and the second to the blower resistor on the HVAC box in the passengers footwell. The blower switch simply controls the blower fan speed with a green wire going the the firewall plug(and off to the blower motor itself). The thermostat plug itself grounds to the harness with the black wire and sends a blue orange wire to the firewall plug(I'm not sure if it's any different to have it ground to the metal dash structure as opposed to going through the dash harness). These are the only wires in the circuit and should run the entire system. According to the Haynes manual, this should be how 91 to 96 works. The earlier 87 to 90 is very similar, with differing colors for wires. The main input plug. This feeds the whole system in the cab. The blower switch plug. This selects the speed of the blower fan The thermostat plug. Sends one wire out and grounds to the dash harness. The blower resistor plug. Controls fan speed The 4 pins. In the engine bay I found something interesting. Despite my new(to me)harness from a 91 not have AC equipped, the engine harness still has the components for it. It has an attached low pressure switch plug(that I'll have to replace with the one on a newer harness, but uses the same color wires), and the AC relay, rather than being empty, is fully wired, so I believe the ECU is equipped to handle AC even if the cab harness is missing the necessary parts. I won't know for sure until I start the vehicle, which is going to be a long while, but I can't see any reason it wouldn't. The AC relay has dedicated wires that are only part of that system that route to the ECU. Any questions or additional info, let me know.
adding AC to a non AC truck
drcomanche replied to ICEBOX's topic in MJ Tech: Modification and Repairs
I'm going to start a new thread on the technical info for the swap to eventually become a write up. I have a good bit of the information for it so hopefully it can help those that don't have a direct donor to pull from. -
I suppose I should have clarified more, but yes, cut the braces the po made as close as possible using a metal cutting disc, then use a flapper wheel/grinding disc to eliminate the rest. I tend to generalize a bit when talking about "grinding" to anything that I use the angle grinder for. I hardly ever use a grinding wheel when there are better alternatives.
Judging by your cross member, looks like you have a long bed truck. The rear of the frame only looks like he welded tabs, which will be easy to grind off. We will need to see the forward portion to know if he hacked anything up there, as there are 2 bolt points that stick above the frame. Otherwise, it looks pretty untouched. In the third picture, though, I do see some rust poking through. May want to address the inside of the frame before mounting a new bed. Or if you're going flatbed, cut the whole thing and build a frame for the rear. As far as putting a new one on, have a buddy help you carry and place it. It's only held down by 8 bolts and the fuel tank. I've even worked my way around doing it myself.
I'm currently in the thick of it trying to install a system from a 96 XJ on mine. I'd be fine starting a new thread on it where we can discuss all the technical stuff(so we stop beating the proverbial dead horse). From what I've researched, wiring wise, it's not too complex a system to get into and usual just feeds back into itself. If I can manage to pull it off, I'll make a write up for it, but having another thread to bounce ideas around would be beneficial as a technical talk section. -
Brake Prop Valve Necessary?
There was no other brake components on it since I've had it, so no distribution block or anything. I figure I'll grab the xj model which does rear brake distribution at the block vs the mj which does it at the load prop valve and then also have a dialed valve for the rear. I'll try to get one with a sensor, as having a warning light would be useful. -
I forgot that the mj had a load prop valve. In my case, there is no valve. All I had was an adjustable valve in the engine bay with a single line to a t fitting on the rear. It makes sense for me to have it, since mine doesn't haul anything but a spare and a fuel cell. It's strictly for fun, so it won't be filled with anything more than that. -
So the short story is, I'm switching my braking to a dual diaphragm booster to stop the monster tires. When I took it out, I saw that the front brake line just went to a t connector and then hard lined to each sides ss to caliper. The rear was a single adjustable prop valve(that was seized). Because this is how it's always been, I never thought much of it, but I've also never had ideal braking characteristics(it tends to sway back and forth under a heavier brake load). I'm not sure if that is due to the uneven distance the fluid has to travel for one side or if the lines hold an equal constant pressure. After researching some, I found that there's generally a proportioning valve that mets out brake pressure. My question is, is that necessary? Will I have better braking results by adding that back into the system? I researched on here and found a thread discussing internals and ideal setups, but that was all with relatively stock brakes. My Jeep runs on a d44 9 inch axle combo with the large disc brakes. I really don't know if that makes a difference.
DrComanches Project "Frankenstein"
drcomanche replied to drcomanche's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Thanks, I'm working on a writeup for them. I've had more than a few requests on how they were done. And now some pics of the shows from OC And a little flex when I got back.- 146 replies
Thanks, still rolling and giving me hell while it's at it. It's come quite a ways since the days of old. Another big update, since I always kind of fail to get back to this build thread. So after all the prep for this show, I decided I was going to take it out to Ocean City Jeep Week this year. To do so, I needed to get it geared up and ready for a 3+ hour trip out there. Mainly, I needed some quality of life fixes for it so that I could survive the trip with my sanity and my health. The most pressing matter was to figure out what the heck was causing all the noise in my front axle when it was in 4wd. I removed both hub rotors, spindles, and knuckles to get into it. I figured, even though there was hardly any miles on the set of wheel bearings in there, I would replace them since I'm there. When I took everything out, I did find some interesting things with the spindle. The noise was my outer axle shafts pushing against the bare metal of the spindles. For some reason, they had some play that allowed them to contact which ate about a quarter inch out of the drivers side spindle. I mulled around ideas for a bit and tried to diagnose it, but came up with nothing. The turning should re center the axle shafts at the ball joints anyway. Well, eventually I found my answer while prepping the inner and out shafts(rust removal and some paint). Turns out, the ones that came with the truck were, not only, the incorrect sizes (came from an ifs bronco making them a half inch longer), but were also 2 different shafts themselves. I bought new chromoly outers and put them back together. While I was there, I did notice some water in my diff when I drained it. The seals seemed fine, so I'm going to chalk it up to poorly placed axle breather, moving shafts, and all around poor quality control on my part when I scrambled it back together before. I painted my diff cover and did some small welds on my old breather port to better seal it. While I had the axle dropped, I adjust some axle placement and painted up my bump stops. I fixed my spring retainers so they weren't bent and finished painting all the steering linkage. Another big problem was that the engine, while it ran, would have a sporadic miss at idle and while driving. I replaced every remaining sensor on the engine except for the cps, and nothing was able to fix it. All new injectors, spark plugs, everything... To help combat the heat in the engine, I ended up replacing all the hoses, sensors, and housing for my cooling system. It hadn't been done since I got the truck, so it couldn't hurt to do it now. I also did an oil change while I was at it after a bit of debate. I should have done a transmission fluid change for reasons I will talk about later. I also wanted to have a stereo for the trip which presented its own challenges. The old stereo wiring was rigged up poorly(just enough to work with the old setup), so I had to get back into my wiring AGAIN, and figure out what was up. Took some real troubleshooting, but I got it to work eventually. Had to custom make a bracket for it too. I rebuilt my rear driveshaft to, hopefully, get rid of some of my vibrations. This also meant I could take the time to repaint it while it was out. The last thing I wanted to get remedied was to wrap my exhaust downpipe to keep some of the heat out of my floor boards. Long trips tended to cause some extensive heat sink into and through the floors. That was another simple project. So the time came and I drove out to OC. The trip out was surprisingly easy. The driveshaft rebuild eliminated a ton of vibration, but the unbalanced wheels did still cause a bit of trouble. It was a nice high 70s day, so it made the temp very nice. Everything seemed to work very well... Until I made it there. As soon as I entered OC, I noticed that it was a bit difficult to get into gears. The engine also started feeling the heat, causing the #3 injector heat soak issue. With those issues, I was still pretty close to my house, so I made it fine. I let the truck rest for a few hours and then went to the show at the convention center. It was a nightmare. There was no parking for 5+ blocks in all directions, as they didn't block the lots off for just participants. I drove for a half an hour and couldn't find a spot anywhere. I missed the deadline for the show and since I couldn't find a spot to park, I couldn't register either. Instead, I just relaxed the rest of the day fishing. I went to the show the next day, which was more of a vendor affair, and found some parking in the main lot. Lots of looks and tons of questions, but I finally found my way in. I debated on registering, since there was only one more day of it(I didn't plan my trip quite right on the time), but decided to since there would still be an obstacle course, a beach crawl, and a show. I got so see quite a few Jeeps at this one, and quite a few vendors. The next day, I played it safe. I didn't want to risk the truck overheating while trying an obstacle course(the trans was getting worse and worse, and the truck was getting hotter WAY faster), so I just went to the show as a last ditch effort to enjoy the festivities. It started out slow, but it turned out to be really cool. I met the director of OCJW while I was out there(didn't even know it was him) and he invited me back next year to put the truck on display! I also met a writer from JP magizine who wanted to do a feature when I got the chance. Then I won an award for it, so all around, a fun experience. I spent the rest of my week in OC just enjoying the weather. The trip back was far more difficult. The day was easily in the 90s. The truck heated up very quickly, and as a result, the trans heated up too. Shifting was very difficult and I had to stop in Annapolis to let it rest for a couple hours. I did an on the fly trans fluid refresh to help it along a bit. The engine was running poorly and for some reason, the charcoal canister flooded with gas. Not sure as to why, but it had to endure. At about 20 minutes out, the passenger front brake locked up and overheated 10 minutes later. I limped it back home from there. From there, the truck sat for a few weeks while I contemplated what to do next. I did take it to a friends place to test the compression to try to diagnose the engine miss. I was told when I bought it that the engine was rebuilt 15k ago. We tested all the cylinders and the results were.... 150 across the board. No fluctuation on any cylinder, so it must be somewhat true. My best guess is that something in the hackjob electrical is shorting out or poorly conducting. Now it's ready to go down under the knife again while I prep it for next year. Many things to come soon. Broken clip and rusted in. It was tough to get it apart An upcoming project Still pretty nice in there, aside from the water. Pulled hubs and spindles. A look at the damages. I pulled the bearings and replaced them with a cool hardened poly bushing from wild horses bronco. The obvious differences Primed and painted Painted driveshaft. The new and old And back together Heatshrink before taped Washed and ready In OC Awards- 146 replies
Rpm dependent hum from front
Sorry for the late responses. I don't take it out much right now, so I don't get to test very many things. In all cases stated above, the noise stops. -
When I take it out of gear, the noise ceases. All the u joints across the entire vehicle have been replaced withing 1000 miles. I rebuilt both driveshaft before I went on the trip. -
Engine mounts seem fine with cursory inspection, no crack or failures and no dry rot or wallowing on the rubber. Harmonic balancer seems sound looking at it while it's running. A little dry rot, but not too bad. I'll test it out when I get the chance. I did it yesterday but can't remember if it did. -
When I was leaving Ocean City Jeep Week a few weeks ago, I made it about 30 miles out and then felt something change. I could feel a very slight vibration suddenly in the pedals at certain rpms and when I accelerated with enough force I could feel it get a bit more noticeable and start creating a humming noise. It only occurred when I accelerated or, to a lesser degree, when I reached highway speeds and the rpms settled at around 2300 to 2500. It made the trip all the way back, granted i was babying it a bit, and then it sat until yesterday, when I drove it for about 30 minutes. The sound is far more pronounced now, at some points managing to compete with the engine noise, and began doing it when at low speeds in higher gears as well. The sound seems to be dependent on rpms and gears, as lower gears (1 and 2) don't make the noise at all, that I've noticed. The hum doesn't change pitch, but that may be because its only rpm related, not speed, and my rpms stay at 2 to 2.5k at all times. It does get louder and more pronounced the faster I go(since its raising the rpms). It's a 93 cherokee 4.0l, ax15. I've dug through a ton of the engine over the past 6 months, so I'm hesitant to say its engine related. Maybe worth noting is that the clutch seems to be getting more obstinate, so maybe throw out bearing?
Since there's no real suggestions here, I'll throw something up and see what the collective techs think. I've been steadily prepping parts to go back on and while prepping the axle shafts, I noticed 2 things. One is that one of the inner shafts has experienced a u joint failure before as I can see some metal deformation where it pushed against the outer edges. The shaft itself seems straight and the yoke looks aligned visually, but I don't have the tools to check fine measurements. I'm not sure how or if some incorrect angles could effect the play in the axle shaft, but I figure there could be a chance. The second is a far more noticeable problem. My axle shaft outers are 2 different pieces. The measurements are close but off by about a quarter to a half an inch, including extra metal at the bottom of the yoke. This seems like a surefire reason, since it's slightly longer putting it closer, but it still brings questions about why it took so long for symptoms to appear, why it only does it after about 5 minutes in 4x4, and how it achieves such force against the spindle to grind that much out of it. I'm not sure what this spindle came from(probably a non transferable later year bronco) but it does have an extra snap ring space as well.
I went to diagnose the noises I had been hearing in 4x4 and also do basic maintenance, so I disassembled the hubs and pulled the shafts. The noise that led me to this point was a very loud metal on metal groaning that got worse the more it moved. When I took the hub apart on the side the noise was coming from(had to put it up in the air and let the wheels turn to figure it out) I pulled the spindle and it was eaten into by the axle shaft. It managed to chew straight through the seal and took a good 1/8 inch out of the spindle. I'm not sure if the spindle itself is salvageable, considering the damage to the area where the seal is supposed to seat. Because I was doing u joints and general maintenance, I also took apart the other side to see that the axle shaft on that side, while not hitting the spindle, had completely eliminated the seal, no metal left, just the rubber ring stuck around the shaft. So, I'm all ears to what might cause this drastic of axle shaft movement. The axle shaft snap rings were firmly in place when removed, so there shouldn't be movement from that. The axle is a D44 Front axle from a 70s Bronco. Also, when messing with the axle shafts while everything was together, there seemed to be no noticeable back and forth movement, at least by hand.
They are hosted on imgur. Even with ccs own server, it ended up being too large when I last attempted. Although I may not be doing it correctly. Outside of that, it is still an extremely long page.
Hey, on my build page I post enormous amounts of pictures. It makes it take forever to load and scroll and each update I keep giving is just tacking on to page 5 without rolling over. Is there a way to manually start a new page so everyone reading and I don't have to scroll for a mile to get to the new stuff?
Another big update since I've been nonstop working on it. Ok, to start, I didn't have time or money to finish out the exhaust system, so for the time, I made a temp solution so it's able to be removed freely. This involved cutting it off at a point so I could weld a sleeve on one half and cut a notch in it to make a tensioning pipe. It worked perfectly. No exhaust gas appears to be leaking through, and it's nice and easy to remove later for a new exhaust. Just when I think I'm done with the bed, I find more problems. So while prepping it up for bedlining, I found a bit of rust near the back of the tailgate and I took the wire wheel to it. It punched right through the bed. I then realized that where the rust was trapped between the two pieces of metal it was bulging up. And that just happened to be at every single spot. I made another quick solution by holesaw drilling a 1.5 inch hole between each of the ridges. This allowed me to pry apart the metal portions, scrape out the rust, and really get in there with a rust reformer. Then, I went to bedlining. Unfortunately, I underestimated how much I would need(in addition to forgetting about the tailgate and wheel wells) so it ended up with only two coat. They sure are tough coats though. I'll have to buy another kit of Raptor and hit the last parts. After that, I mounted it up on the frame. From here, I mounted the fuel cell first and then set to putting together the handbrake. I had all the parts and a relative idea of what I wanted but it still took some work to get it together. The e brake cable(a random 20 dollar buy that had no fitment specs for my vehicle) fit perfect with just enough room to move. I bought some springs to pull it back and give it rebound and used some rubber coated cable clips to mount them to the one of the bump stop bolts. The cables themselves came with a metal sleeve that I put inside the clips to allow it to slide in a controlled direction through it. So, in short, it won't ever contact the tires. The only obstacle I still had was to fab up a bracket to hold the cable sleeve from the interim cable(handbrake to the splitter). I started to make it and while letting it cool off from drilling, I was putting together interior stuff. In the process, I found a bracket that had previously held the vent tube for the rear diff. Lo and behold, it was exactly the bracket I needed. It seems someone used it for that and it never dawned on me that that's what it really was for. Saved me the trouble of finishing the fab. In the end, the e brake works... kind of. I've upped the tension about 5 times and am still having an issue with getting a good hold. However, the fact that it is together and functions almost as intended is pretty damned good. I finished up the wheel wells in a couple days, but upon fitting, I realized that the light bar was mounted at the very edge of the old, meaning it needed to be mounted at a weird four measurement angle. So I started cutting up my fresh metal to make a spot for them. I did many rounds of measurements and rough ins and am pretty damn proud that it turned out so perfectly. I doubled the welds on all the parts of the wells, which gave it more strength and a better look, and then painted them quickly(2 days from deadline). I mounted them with 7 screws each and then the bed was mostly together. The fuel cell was always my biggest concern for the endgame of this seasons buildup. I, having not done fuel lines, was concerned from what I heard about PTFE tubing. I pretty much fully expected it to leak, especially on the sending line since I had 2 5/16 quick connects to hook up, but they only had outputs for 6an and my line was 8an. That meant I had to have the quick connect to a 6an to 8an step up to the 8an line in 2 different places. I also worried about the initial startup with the new external pump, as it says not to run it dry, but I had to pull some fuel into the line. I spent 15 minutes trying to start it with no turnover. I was worried about running the pump to death or killing my starter/battery. I disconnected it at the fuel pump and a bit of fuel poured out before it was even fully taken off. Good news for the pump. I workshopped it a bit longer before getting to the quick connects on the fuel rail and popping the return line off. Then I found my mistake. Accidentally mixed them up at some point. Blew fuel everywhere from the built up pressure, but hey, at least the line was pressure tested with no leaks. After that, it started right up fine. I had to create a spot for my vent line to connect to the canister(which, surprisingly, it never was). I put some rubber bushing between the cell holder and the bed, which were actually just extra large soft rubber furniture pads. I pulled the metal washer out and it worked great. Then some stickers for the finishing touches on the cell. I finished putting the tailgate back together and installed it too. Then applied some decal stickers from Jeepsticker.com that he made for me. I finished mounting the bumpers, which was incredibly hard in the rear with the extra 1/4 inch of metal on each side. I mounted and wired in my winch and offroad lights after running completely new lines for it. I finished installing the skid plate(with the new trans mount which knocked out all of my shifter vibration) before all of this and had the hardest time installing the new straight connection tcase linkage. In the process, I managed to smash 2 of my fingers really good between the trans and driveshaft, enough so that they were purple and green all over up to the first joint. May have broken something, but it's mostly healed now. Connected all of the front end stuff and repainted my steering linkage and tie rod. Installed the newly rebuilt driveshaft. I finished up the interior. Then came making the custom aluminium plates for the fuel gauge and the switches. The fuel gauge I had to get creative with for the wire out to the cell. I ended up just patching it in to the old fuel gauge wire and then running that out at the pump to the cell. I used the other 2 wire for a direct plug to the fuel pump. I did some troubleshooting with the jumble of crap wiring to find good power sources for everything. I'm not sure if I mentioned it before, but I switched all of my lights out for led replacements. All of them work perfectly without the extra inline regulator, too. I originally switched over because I tinted my tails and turns so I wanted something brighter for safety. Last but not least, I finished the trail door interior panels and washed the truck. The exhaust cut with the repair an exhaust shop did a while ago(poorly) and the sleeve piece welded on. The bed "mod" for the rust All bedlined On with the fuel cell mounted up. testing the wheel wells The start The modification for the light bar Looks good. Cell vent line mounted back there The underside with pipe foam to keep rubbing on the bolts and edges to a minimum. It doesn't look pretty, but it's solid. I mounted the fuel pump and filter here too. My rubber shock mounts for the cell holder Last minute stickers All hooked up. All grade 8 bolts Mounted and wired The bracket I had just laying around The fit before the metal sleeves were mounting up Doors Tailgate. The uneven lines bother me, but I'll have to fix them later. Interior Gauges Painted up Now I've been pushing really hard on this for the past 2 months. I've been working on it every day, blistering heat or rain, into the night, etc. all for a show in my area that I missed last year. The Budds Creek 4x4 Expo is a big event where they open up trails, have a show and shine, a car crush, rti ramps, raffles, vendors, and all kinds of stuff. I knew back in December I wanted to attend. This build has drug on and on for ages because I keep finding things wrong and don't want to just slap it together and call it a day. It took literal blood, sweat, and tears working to get this done. And a day before the show, it finally was. It fought me every step, too. I drove it all that day and then to the show as well with no issues. I showed up there and turned the truck off to fill out the necessary papers. Took about 15 minutes. Went to start it back up and nothing. No turnover on the starter. Get a jump start and get it into the grass where it belongs and it dies again. Seems like the alternator. An event staff person offers to take the battery and recharge it for my while I troubleshoot. I call a nearby Advanced to see if they have an alternator. They have one. Another Jeeper there helps me get the old out and gives me a ride to the store. Get a new one and install it. Finally starts perfectly. Finish the intro stuff and they open the trails. Decide to put it through the paces but when I start it and try to move, there's no pressure at the clutch pedal. I check the fluid and it looks fine. No leaks on the lines. I'm pretty much grasping at straws checking the entire system over. Then I find it. My clutch pedal chose this time of all times to crack at the sleeve over the bolt and the pedal is just flexing out on the clutch side. Noone at the show has a welder so I'm giving up hope for it and trying to plan a tow. Then another guy asks about it and I fill him in on the issue. He makes some calls and reaches a buddy 5 minutes away who has an old buzzbox. I wrenched the pedal off and we put some touches on it. Finally, a driving vehicle. I'm pretty down at this point and don't even want to take it anywhere for fear that it'll break again. Eventually, I decide to baby it on some easy trails. Get it moving in 4wd and get about 100 yard and hear a noise from the front that sounds like a dying dog. I turn around and go back to the field to try to replicate the sound. Couldn't make it happen. Did an inspection on the front and couldn't see anything wrong. All the front end parts have less than 40 miles on them. I debate for about an hour on what to do. Eventually, I decide to take it out anyway, since it only happens when it's in 4wd. Fun side note, on my way to the trails a guy runs full sprint to ask if he can ride with on it since he's a big fan of Comanches. It whines like a beat dog, but it flies through every obstacle. The noise is definitely something to do with the axle shafts since it whines in rotation with the wheels. I ran it through a couple of times, just enjoying myself and getting Frankenstein a little muddy for once. Then I enjoy the rest of the show looking at Jeeps and watching some monsters run over the cars. I swear I talked to every person there answer questions about the trail doors and the frame, the fuel cell, etc. And at the end of the day, Frankenstein won best in class. In the end, I had a good bit of fun there, despite the trouble. As a final thought before the pictures, I know it's my own build, so I'm biased, but it is everything I had in my head that I wanted to come out of it. It is the exact look I was going for. While the build itself will be slowing a bit for some time, it certainly isn't done. So now, enjoy some pics of a finally finished truck and some cool show stuff. The rescue vehicle for a section called "milkshake" that killed about 20 vehicles that day Some crushed cars- 146 replies
Big post coming up, so prepare for a read. I see that I've been upgraded to the Epic Tech forum, which is awesome. I'm not really sure this build is deserving of it(no motor swaps, truggy builds, or crew cabs here), but glad to be a part of it. To start with, the idea of using the old brackets from the hood springs didn't work out. They weren't stable enough to stay straight, so I ended up having to fabricate a solution to the issue. I uses some leftover angle iron I had and made a 3 sided piece with a slot at the top and a welded screw on the forward side. The other flat would tuck against the inner fender to keep it from rotating. I wanted to build it so I didn't have to remove the tension pin in the bottom every time, so instead of having a sealed slot, I cut it to one side and added in catches for the spring to keep everything in place. That, aside from some adjusting, finished the hood pins. I had to cut the fuel cell holder back apart to figure out why it wasn't fitting and adjust the measurements. This made the end product look slightly less professional, but it's hard to even tell. Turns out the fuel cell isn't square, so it threw everything out of wack. I gave it plenty of room to move this time while still being relatively tight, painted it up, finished the top plates off, and bolted it all together. All finished. I sized it up in the bed and drilled my mounting holes while I was at it. I finally cut into my hood to place the vents. I put them further back than they would generally be, which had the bolts going through the back support of the hood. Nothing a few longer ones from the hardware store couldn't fix. I made the holes a little larger than they should be so I can do fine adjustments(it always bothered me to see vents that were slightly off from each other). Another easy job done. Then it was time to tackle some of the harder stuff. I painted my frame and floors up with a POR 15 tie coat primer to aid in adhesion of the next coat which was a chore(every painting session with the frame and cab is). I used it to fill in some of the imperfections as well, which were enough to peak my OCD. Now, I eventually prepped up to do the rock rails with bedliner and had seen someones post on here showing a frame they bedlined. This got my mind jogging about if I should do the frame as well or not. I hadn't planned for that amount of bedliner, so I had to order more. After some research and an extended amount of sanding the tie coat, I decided to do a coat of POR15 and let it tack up for an hour and then do the bedliner on everything. And it turned out awesome. The bonus is, it covers imperfections better than the tie coat, and it acts as sound and heat insulation on the floor. Win win. I then moved on to the next set of bedlining which was the front bumper, the cab rail plates, and all the lower quarters(except for the bed, which is going to be it's own step). I spent hours sanding every little corner of the bumper. Since it hadn't been properly done before, there was a good amount of rust in all the corners and edges. Eventually, I did manage to finish it, but it was tedious. I took all the parts, laid them out on a tarp and taped them up, then sanded the finish. It ended up being too hot to shoot immediately, so I waited it out till it was in shade and hit it. The turnout was great. Raptor Liner seems to be a really good product so far. I had finished sizing up the seat brackets for the rail plates. I ended up getting a loose measurement of height to start and then cut the steel from there. Then I welded bolts into them and bolted them to the seats and laid it back on the plate to tack it in. I used some leftover 3/16 square tube and cut them essentially in half then did a two pass weld to the plates for rigidity. At this point, I think the stock bolts will break before these do. After the bedliner was dry, I put a rubber seal on the bottom of them to keep water in the cab out of the rails and bolted them into their new home. I've got to say, I think it looks pretty cool with that setup. I really wanted to paint the edges of the tailgate so I started working on the bolts for the latches. And what a PITA they were. Every one was stuck solid and they just stripped out. I ended up cutting one down into a hex standard, but even that was hard to remove. A lot of time and some very choice words later, I decided to roll out the big guns and welded a nut on top of the remaining bolt. I had no intention of reusing them anyway. Outside of that, I still had some rust in the bottom so I ended up drilling out 1 1/4 inch holes on each side of the gate edges. This way, I have clean access and can just plug them later. Now I can clean inside of the gate easily. Now, the real problem child came up. The bed was rough to start with and an incomplete job dealing with it last winter meant I had a lot to look forward to. There was still plenty of rust under the support rails on the bottom, in the edges at the back, and all up and down the inside around the wheel well. The wheel well seems were very poor all the way around which led me to my decision. I cut the wheel wells out. I did it as clean as possible and planned to make some new one that just bolt on(since I'll be changing up suspension back there eventually) while leaving some lower portions to weld to the outer shell for support. It got rid of a lot of bad parts but added a ton of time and effort. After that I began working on the bottom of the bed. I'd say about half of the contact points between the bed support rails and the bed itself were a quarter inch larger from the rust in between. I broke it down as best as I could and did POR15 on the rest to, hopefully, convert what was left. I used Eastwood frame coat on the inside of the support rails. There are still concern spots, but I'll just have to deal the best I can. I really want this bed to last with all the effort and money in it. Since the inside of the bed edges were so narrow, I had to hand sand the entirety of the inner shroud parts. It took a while but really shook off and cleaned up a ton of rust. Then I hit what I could reach with POR and the rest got eastwood. I began making my new wheel wells and at current, have one of them pieced together. It isn't fully welded yet, and I don't have a picture on here, but I think it looks cool. A lot of sizing and adjusting for the curve in the bed edges. I also have to customize the tops a bit to fit the roll bar foot, with meant cutting 3/4 of a square and angling it. Later on, I'll fill the empty space with metal. While I was doing the Eastwood coats, I went to the interior of my frame rails. I had done this last year, but I already knew the coat didn't hold up plus the welding of the stiffeners had burned off some as well. This time, I made another, heavier, tool to get in there and really break it up. I used the cable from before but bolted 10 links of a chain on this time. Attached it to the drill, and let her rip in there. It knocked a ton out. Many rounds of vacuuming, air blasting, and washing later, and it finally got the Eastwood coat. At this point in time, I'm actually getting closer to the end of my list so it was time to start reassembling things. I put the fenders and front end back together with the addition of led corners, bottoms, and headlights. I replaced all the fender bolts with flanged hex heads to make it easier on myself. I need to buy new fog lights and I'll probably bedline the grill and light shrouds, but that'll be another day. I also put most of my interior back together too. I still need to install my boostwerks t case shifter upgrade, so I can't put the console or seats in yet. For a while, I've had this idea in my head for a pillar handle to get in and out of the truck, and decided I was going to customize a way to work it in. I purchased some smittybilt ones a while ago. I ended up shaving out a slot 1 inch below the screw hole in the a pillar trim(I'm a sucker for perfection, so I wanted to make it look stock). I used that to slide to hole in the handle strap to where the mounting screw would go. Then I screwed the trim in with a heavier duty screw for a sturdy hold. The other end of the handles is bolted through the drop support for my shelfit. I put the bolt hole as close to one of the mounting holes as possible to prevent the bracket from bending and warping. Then I put 3 heavy duty screws in that one too. The result is a nice, clean, natural look and a sturdy as hell handle. Lastly, I finished the hardware on the trail doors and mounted them up. I like it. The brackets. You can see the little spring retainer on the main piece And they work Good to go Mounted it in to size it up again a few extra welds and parts Bolted up and finished Scary step. Didn't want to mess it up Painting the edges to prevent rust Tada The Tie coat. This stuff went on really thick Prepped for bedlining first coat Third coat finish Various parts, ready for bedlining Done I put the doors and fenders on while they dried. I'm lacking space for all this in the garage bought some grommets from the store. They fit perfect and go right around the bolt. Should help prevent chipping and rubbing Floor plates all done Tailgate hell More rust just from turning it sideways POR coat Goodbye rusty wheel wells Also removed the fuel tank bracket that were harboring rust The beginning I talked about my diff breather thing from arb. Here it is with the tcase breather so far. It can mount up to 4 Getting close All set.... Mostly Grab handles Trail doors The starts of my fuel line work- 146 replies
