codymanche
Everything posted by codymanche
  1. i do but they never did that until i got a new deck. and i have checked those wires numers times. like when the blinkers on the dash dimer out so like a blink and when they are off they are fine same with the brake but not as bad like the turn signals. and i have an automatic so i don't worry about fuses being corroded. and my next question is could it be my battery I'm using a optima yellow top and when i changed batteries at the same time with the deck
  2. well would it be good for jeepspeed I'm not really looking to climb
  3. but why not bolt on
  4. head light fixed- yes, but need one more new turn signals harnesses installed- yes, both dash still binks with either turn signal on and hazards on- no, i don't know what to do i don't know what else to do they work but i have to turn my lights on for them to work. they won't work unless u turn on ur running or headlights to turn on ur signals.
  5. okay i got the parts they didnt have them when i went so i ordered the round about 20 for both. just got off work. ima try and do this really quick hope this works
  6. and why is that? i wanna keep the rear end that i have i been told its a 44 with limited slip and i don't wanna cut or mess something up if i don't have too such as a weld
  7. is the kit from hell creek bolt or weld?
  8. thanks i had a friend who did something similar and had a switch just trying to get ideas. i wanna cage the rear with a tire rack that can hold 2 tires and a jack and hi lift
  9. its whatever!!! some people help out and they don't have a problem with it! or maybe u can slow down and read. ill try to fix it but habit is something from work and that is what i do all day is short hand stuff and that,is the NAVY for you! but i'm not mad about it and really don't care! more like high school drama if you ask me on here we are all adults on here looking for answers and help ill try and fix a habit on here!!! so it makes everyone feel better on here and to get off my back!!! about this **************************************NEW POST************************************************* well!!!!! i cut my fenders for wheel travel!!!!! when i get "twisted" as we call it out here and i don't rub at all! i have a coil spacer i believe in the front and i fit 33x12.50r15x10. i rub a little like on a hard turn but no sway bar either so its like a sec and goes away!!!!!!!!! lol but i have another set out rims that i wanna put on the are a huge offset and never rubbed! a buddy of mine has them on his cherokee. he likes them and they are 15x10. they look too wide. will not need wheel spacers!!! i saw a wheel spacer break on a friend and ended up getting a axle in the end.
  10. well in another discussion there is another person with a similar prob that i have. he was told to do the harnesses and from what he said that worked and for only 8 a harness I'm not gonna complain
  11. I ordered the harnesses that everyone was talking about. and i was just going to replace harness and the bulbs. I also have no clue what a sitrep is? Let alone how to test it!
  12. come on man your on the computer, texting, working in the navy, you use short hand. Its a habit that they get you in during bootcamp. if you know anything about that. since it sounds like you do not know and sounds like you are a teacher! if its that big of a deal then don't read the post i put up!
  13. wel i cut my fenders for wheel travel when i get "twisted" as we call it out here and i don't rub i have a coil spacer i believe in the front and i fit 33x12.50r15x10 and i rub a lil like hard turn but no sway bar either so its like a sec and goes away lol but i have another set out rims that i wanna put on the are a huge offset and never rubbed and a buddy of mine has them on his cherokee and likes them and they are 15x10 too wide and will not need wheel spacers i saw a wheel spacer break on a friend and ended up getting a axle.
  14. okay so i replaced the headlight that was out. might as well buy another, cuz its way brighter then the other. while i was changing the headlight, I opened up the passenger turn signal. the bulb glass is loose so i just left it. it still works. also yes the hazards make the dash blink and just playing around in the truck, I turned on the fan while the keys are out and the lights were on. wierd. but i roll with windows down not worried about it but just throwing it out there. new windshield wipers on too and paint to fix my white hood and fender nothing a lil rattle can can't fix haha
  15. those lights on the rear bumper are they on a switch or connected to the reverse lights i wanna do something like that
  16. isnt 210 temp almost too hot i know a couple of my friends in az when they heat 210 we turn our e-fans on we rigged them to a switch so when we sit for a lil or whatever the case maybe its on and my old man said 210 is too hot. but i had a bad cap and started leaking coolent when i got to 210 replaced the cap and now i havent even touched 210 but i havent went hard in the dirt either lately so enough with blah blah is it suppossed to be 210 for opperating temp
  17. which one do i replace or should i just knock out the both right away
  18. hornmrod where can i find that visor like u did
  19. ima try this weekend is it just one or did u replace both
  20. the smaller fuses are okay they have 15 in them and i got a headlight out but the guage lights blink when the turn signals are on. could it be a relay or the switch also my wipers are slow could the motor go out and ur package thank you btw ima put new the stick on this weekend and ill have u put a new pic up for me
  21. okay i got confused i checked my fuses they are good but my passenger side head light is out I'm thinking a new light unless its a relay but my turn signals do not work like normal. when i turned my headlights and running lights on they work could it be the turn signal switch relay or what u guys were talking about and where is that at on the turn signal if u guys could i can text u when I'm doing it to follow and theres no need to be a smart @$$ on here i have a similar prob not the same 7028837044
  22. yea it is haha till i get a better one
  23. i replaced the flasher the circular one on the bottom the guages one but the diagram one that u have is different then what i have
  24. okay well i can put a pic on my profile even the ones u gave me are too big
  25. no i don't auto not sure what tranny i have either but its a 1990
