19Comanche 87
Everything posted by 19Comanche 87
is that what the bubbling in the Coolant tank is?
does the coolant just leave the overfill tank on its own? if not then how do you get the coolant to drain from the overfill tank
the upper radiator hose is the hose that i replaced and lost the coolant from originally. the issue is I'm not sure how much i really lost when i changed it.
i have the same setup as the pictures in the link above. 4.0L with the plastic overfill bottle.
i did loosen the smaller hose on the thermostat housing and coolant started coming out. does that mean there's enough coolant in the system? i keep seeing bubbling in the coolant reservoir so i figured that the air was trapped and needed to get out somehow.
NEED HELP! I'm totally stupid when it comes to the comanche coolant system. i had to change a coolant hose the other day and lost some coolant in the process. i added some to the overfill tank but i don't think any went back into the system. i have ran it and got it up to temp a few times and still don't notice a change in volume in the overfill tank. I'm not totally sure how much coolant i lost but i would have thought more would have left the overfill by now. my question is, can i just remove the coolant reservoir cap and run it to get the air out of the system? also, is it bad to run it with air in the system? i have the dummy light and its never come on so i don't think its over heated yet. but i don't know if having air in the system is a problem or not. any help or advice would be appreciated.
Question, would this all be the same process if i wanted to just slide the bed back enough to paint in between the bed and cab? would i still need to drop the gas tank?
Emissions FAIL!!!
19Comanche 87 replied to 19Comanche 87's topic in MJ Tech: Modification and Repairs
the one i used i think was a bosch. might have to try and find a junk yard one to replace it with. -
Emissions FAIL!!!
i replaced the o2 sensor with an aftermarket one and it didnt look the same as the original. i wasnt able to find an oem sensor so i just went with the aftermarket. could this be the cause? do all o2 sensors look the same or can they look different and still work? still new to all of this. -
Emissions FAIL!!!
i don't have a copy at the moment. i will be running it through again tomorrow to see if it will pass. i did find a small exhaust leak just before the cat. not sure if this would be significant enough to fail emissions. ive never really worked on a car that didnt pass emissions so all this is kinda new to me. ive replaced the spark plugs and had some seals replaced. it was having a hard time starting when i first got the truck but seems to start better. could this be a low compression problem? -
I've been trying for months now to get my 1987 Comanche to pass emissions in DE. it keeps failing with high Carbons. I've replaced the o2 sensor, ran smoke tests for leaks, and tried running "Guaranteed to Pass" in my fuel. when i bought the truck it was tagged in Maryland which didn't have emissions tests. and the charcoal canister wasn't hooked up (red Flag). could the charcoal canister be bad? any ideas as to what is make it fail? its the 4.0l inline 6. its also failing the gas tank pressurizing test. could these issue be related? any suggestions would be greatly appreciated.
i ended up getting mine blasted and powder coated with the "polished Aluminum" from Prismatic. they turned out great! havnt put them on the comanche yet though.
What color powder coat did you use? And what was the brand?
Jeep Turbine 10-Spoke Rims Restoration
19Comanche 87 replied to NEO auto's topic in MJ Tech: DIY Projects and Write-Ups
What size lift do u have? -
i like it!! do you think a 31x10.5 tire would fit on them? I'm looking to lift my comanche but i would like to keep the stock rims if i can. just not sure if the tires will be to big after i lift it. ideally i would like 32x11.5 r15 but that just seems unrealistic for a 7" wide rim -
got any pics of these mounted? I'm looking to do the same thing and these seem to be the only pictures of black turbine rims i can find on the internet. -
2 Mystery cables and screw size request!
19Comanche 87 replied to vanquishings's topic in MJ Tech: Modification and Repairs
Does that metal line then go into a rubber hose just before the fuel tank? And then connect at the top of the tank? -
Does anyone know what the connecting trim peice between the 2 front fender flares is called? Its underneath the front bumper. Mine is damaged and I'm looking to replace it but can't find any part name for it. Is this same peice on a xj model that I can grab from a junkyard?
Just bought my first comanche this weekend and went to replace the blower motor. The comanche came with a new that wasn't put in but it has a different plug then the original. Am I able to just cut the connectors off and put a male female connector on each? Both motors look identical other then the connector. Sorry if this is a stupid question. 😄
