replaced the trans lines, serp belt, IAC, removed the crusty decals, did an oil change, checked the diffs *will open/clean and refill with new fluid soon*, ordered new window trim, new trans mount and engine mounts. Will get plugs and swap in a good set of coils I have, also need to order a new fuel sending unit. Mine leaks when full on a hill and upon inspection had epoxy or jbweld around the inlet pipe. The power steering bracket bolts are kinda jacked. I had to shave off a quarter inch if bolt on the back one and the top one on the front had snapped in the bracket. Someone had overtightened it and stripped the threads. As a temp solution I used Teflon tape to fill the void. And I sawed off a quarter inch on the backside bolt which was not even close to in, but bottomed out. I'm assuming someone used the wrong bolt upon reinstall after a repair.
will update more as I have progress.
Thank you!
Question: at the top of the list it says SA: charcoal.
Is that in reference to the factory paint color? Or something else?
