Muncher
Everything posted by Muncher
  1. I jusy got a battery cable kit and started putting them in today. I could use some help identify things. I've got one cable going from the relay to the pdc but am unsure where the pdc is. I have a renix motor if rhat helps. Thank you
  2. When I pull it towards me with high beams on it turns them off but no low beams or anything still
  3. Not sure what the top rod is supposed to do but it doesn't move
  4. This moves when I pull the stalk towards me but doesn't stick or anything
  5. oh ok. ill look for that. I'm assuming its stuck though because i was playing with it earler and didnt hear anything move. what should i do to it
  6. maybe i didnt look good enough but i ddint see anything running off of it besides the one wire in the back of the light switch
  7. i checked that today actually and when i pull it out to low beam or high beams i don't hear anything near the pedals
  8. That's true. I might still see about maybe having them painted black and I think it'd look better. Because I'm just trying to get rid of the chrome
  9. On some trucks yea but the way I'm going with mine thwy look a little goofy
  10. So I have the tow mirrors on my truck and the more I've just been looking at them and driving the truck around the house a little they kinda suck. What have people done besides new doors or body work to fill the holes? I would do one of those options but the doors just got re done. I thought maybe jusy some carriage bolts to fill the holes for a while. Let me know what you guys have done
  11. Also looks like I'm going to have to quarantine for 10 days so I guess I'll have to be working on my truck
  12. I actually already replaced my starter a couple of weeks ago. Because the old one died out.
  13. I'll have to check tommrow
  14. Yes it was a problem before to.
  15. well the high beams are the ones that work the low beams are the ones that won't turn on.
  16. So j replaced the switch for Mt lights but still no low beams just high beams. What else should I check to fix this?
  17. I don't know if you said it already but what is the material this is made of? also do you have any intensions of doing something like this but in black. and finally what is your instagram.
  18. i will. ill have to document it to once i do it and maube put it in on here
  19. yeah i would probably have it around a inch shorter then my shifter.
  20. yea if not i would have to find some boot to fit in there. but basicaly i would just like the circular ball shifter and ive always liked the classic look of a dual lever system in a truck that has a manual. and i guess it would be a little easier shifting into 4x4
  21. well thats good,. i think I'm going to do this soon as a project to keep me busy during winter
  22. well the guy just welded a bolt to the handle after cutting some of the orginial off so as long as i could do that it would work,
  23. i saw something on a tj forum where they took a bolt and welded it to the transfer case shifter and made it stick straight up instead of the bend, would this be possible on a mj? or does anyone know if the lever is the same in a tj as in a mj?
  24. Just got a upgraded battery kit from k suspension. Not labeled the best but they look very quality
  25. Can't belive that went for 250
