Muncher
Everything posted by Muncher
  1. I do have cruise control which I believe relys on that canister
  2. I think I posted something about this before but where's the best spot to relocate this vacuum ball thats not where the radiator fluid goes. Also under it is kinda not a option either because my winch solenoid is down there for now.
  3. Here is a question for people running subwoofers in a pre manufactured enclosure. what brand did you go with and what model? any good suggestions and and i also am running a bench seat.
  4. Save it[emoji779]
  5. I would absolutely take a pair if the price is right
  6. Still having this problem
  7. Led and normals are both 57 them they have 2 elements
  8. How am I supposed to tell?
  9. Just the ones that were already in thr truck
  10. For the bulbs being the same the I only used two led blinkers and one is currently on each side but when I put two normals bulbs on one side and both leds on the other it wouldn't blink. Which is why I'm confused
  11. Ok. I just re did my ground though I replaced cracked parts of the wire. Brushed down to bare metal and used a actual bolt on it.
  12. Here's the status update. So the front bulbs one blinkers wasn't in all the way and now It works. I think the marker light socket is just broke. And for the rear if I put leds in the middle socket they work and blink. But if I put them in the top they don't but normal bulbs Do which makes no sense to me. How should this even be solved. Also side note with a upgraded ground and new led reverse lights they still don't work in guessing it's the switch for them?
  13. They worked fine before hand besides the reverse lights. I'm going to try to switch the relays and see if maybe that's the issue.
  14. Sirusled, phinlion and Mars auto
  15. Two brake light types put led blinkers in front and back put led reverse lights in and also led markers in the front
  16. I'll try switching it again
  17. My hazards don't work either
  18. There the same style as the orginials
  19. Do you mean the blinker bulb vs the brake bulb
  20. Ohhh. I mean they go on they just don't blink. I'll have to try flipping them around
  21. I think so? How would I tell what the right way is
  22. The lights do work but they just don't blink. I already did put in a led flasher relay as well.
  23. All of them aren't working and I did change to a led flasher relay. Also passanger side blinker and drivers marker aren't working
  24. Finished putting led lights in all the way around and now I'm having problems. When I finished the rear I realized Two lights up front aren't on and once again my blinkers aren't blinking. But the brake lights work. I did re do the ground in the taillight maybe I just didn't do it good enough?
