Everything posted by Thorwon
I'm going to build it back to a 4.0, all I need are pistons. I have the rest of the parts.
What I didn't do was check the original 258 rod/piston assembly weight compared to the new rod/piston assembly weight. What I have found so far. The rod/piston assemblies are 124gr different from the original 258 rod/piston assemblies. The new rod/piston assemblies are lighter by 124gr. All new rod/piston assemblies are less than 1gr different in weight. This weight is including rod, piston, rings and bearings. The local speed/machine shop wants $375 + any heavy metal needed to check/balance the crankshaft.
The power steering pump and harmonic balancer are only things that were new when I put the engine in the truck. Everything else is from the engine I took out of the truck that I built the stroker from. No fan clutch or fan. I'm running three electric fans. The flex plate is from the truck. It's original as far as I know. I have two more in the shop I'm going to compare all of them today.
Well the balancer didn't help it. I guess I'll be pulling the engine, so I can remove the crankshaft. I've got to see if there's a shop local that can balance it.
Good article. I made a spacer for the extra length. My 6 x 18 Craftsman lathe comes in handy for things like this. My concern is the new balancer may be made wrong/unbalanced. I'm going to change it with a used one off a known good running engine.
I understand they are internally balanced. But if the new balancer is not right changing it should tell me. The torque converter bolted up with no issues. I was just wondering if the crank pilot bore may need a bushing for the AW4 torque converter. I don't think the AW4 was ever put behind the 4.2L.
It's the 4 weight crank. I have no pics of it. I'm going to change the balancer, if I can find the old one, to be able to rule that out. Can anyone answer this? Question for ya'll. I'm running a AW4 behind the 4.6, can anyone tell me what the pilot hole in the rear of the crankshaft is? I never checked to make sure the torque converter fit the crank.
Yes it makes it when parked and revving the engine. It's the non weighted crank. I've always just called it the light weight crank. I am positive the vibration get bad as the RPM goes up. Question for ya'll. I'm running a AW4 behind the 4.6, can anyone tell me what the pilot hole in the rear of the crankshaft is? I never checked to make sure the torque converter fit the crank.
The crankshaft was not spin balanced but all the other components were balanced. I checked every thing.
I've built a 4.6L short rod stroker. I used a 1988 Comanche block, the light crankshaft and rods from a 4.2L. SPEED PRO Hyper H802CP40 pistons. The camshaft is a Crane Cam H-260-2, .456 intake .484 exhaust. And a 7120 head. I put a new Dorman 594-018 Harmonic Balancer on it. It starts and runs great, but at about 2500 RPM there's a vibration and the higher the RPM the worse it gets. Idling it's as smooth as it should be. Everything I can think of is right. Anyone have any ideas what it could be?
My 1988 MJ has a new pair of wires coming through the firewall just below the MAP sensor that my CPS plugs into. I guess someone has done something similar to my Comanche. It also has the old CPS wire still in the main harness.
HO distributor in a Renix system?
Thorwon replied to Thorwon's topic in MJ Tech: Modification and Repairs
Thanks for the offer. I have a friend that's bringing 2 over so we can see if that's the issue. -
So nobody can tell me if this will work? -
You can buy the correct fittings to connect to the fuel rail. Just purchase fuel line rated for fuel injection and clamps for fuel injection, then build them. This is how I replaced the lines on my MJ.
I have a 1988 4.0 that I just realized has a HO distributor in it. I don't have a Renix distributor at all. I've taken 3 Renix systems from 3 different vehicles apart and they were all the late model distributor. Is this common or did someone not know what they were doing and install the wrong distributor. What mods are needed to run a HO distributor in a Renix? Or are they interchangeable? This is the distributor I have.
Driveshafts for 2wd to 4wd conversion
Thanks for the info. I'll probably cut mine down, I'm cheap. I've done it before. -
I've done a 2wd to 4wd conversion on my short wheel base 1988 MJ. I'm confident the front driveshaft is the same as the XJ. What rear driveshaft do I use with an AW4/NP231J? Is there a factory driveshaft Or do I have to have one made?
Changing my MJ to a GM computer sys.
Not yet. Life changes priorities for you every now and then. I'll post it when I get the opportunity to look at it. -
Not yet. I've got a friend with an oscilloscope that's going to bring it over. That way I can look at both the CKP and CMP sensor pattern at the same time. Then I can turn the dizzy till they line up. Hopefully that's all I'll need to do. -
So I got the O2 sensor hooked up today and on the short test run I made it really helped it. I'll be driving it about 60 miles tomorrow, so we'll see how it does. I'm running one O2 with it hooked to the input to both bank 1 sensor 1 and bank 2 sensor 1. I'm using bank 1 sensor 1 12v to heat it. I turned the DTC off for the other O2. I've also got the fans running off the computer. -
That's the best explanation I've seen for the SYNC SIG. I wish I would have read it before I started working on this project. The thing is I have those PDFs. I've just never read them. -
The way I understand it, this computer only runs sequential. Each injector has an output from the PCM. What's interesting is the difference in firing orders has to be taken into account. So I had to renumber the injector outputs. Jeep Inline 6 - Firing Order 1 - 5 - 3 - 6 - 2 - 4 Chevy V6 4.3 - Firing Order 1 - 6 - 5 - 4 - 3 - 2 -
Well I've had to change up the distributor. When I installed it I didn't think about where in the crank rotation the sink signal was sent to the computer. I am getting a sink error. I have no way to look at the signal so I'm guessing. So I set the engine at TDC #1 and the reluctor was about 90 deg from the signal coil. I then rotated the distributor and reset the plug wires appropriately. It idles much smoother and runs stronger. This is a learning experience so I'm figuring it out as I go. I guess I'm going to have to buy an oscilloscope. And then learn how to use it. -
Well the computer I'm using isn't the 0411. It's from a 2004 Chevy Astro van. I got the harness, computer and sensors for less than $100 at a upull it. I have put a couple more videos on youtube so check them out. https://www.youtube.com/channel/UCqgfTWTFVHdZk5huUMnj6sg -
Well it runs pretty good for the first time I started it. https://www.youtube.com/watch?v=wxlzG2TspuE
