murdamanche
Everything posted by murdamanche
  1. I am doing a full restoration of this truck, I have the bed off and all power washed ( old pic ) but I’m curious to know the weak spots as to where I should focus my welding the reinforcement. Thanks
  2. I took my old sender out and of the truck and it was the same part number, they used to offer with the pump and without. Now it’s only with so it has to work
  3. i spoke with Airtex and they make this, i just ordered a new one https://www.amazon.com/Airtex-E7091S-Fuel-Sender-Assembly/dp/B000C1IOIW
  4. its all pretty much straight forward, only question is with the new t-stat housing... when i thread in a new temp sensor where will i wire that to? it has a sensor in the head by the firewall and now one on the t-stat housing? am i right or wrong, any help if you know thanks _D
  5. Hey guys, can any body point me in the exact location the gear selector clips to? Yes it’s removed from my old cluster but the PO never had it attached and I’m stumped on where to put it Thanks
  6. Damn, I’ll drive to get them but I’m trying to get the frame sand blasted and coated... it’s so damn cold I might build a small booth to blast it and coat it before hand... not sure just yet
  7. Or I might make my own if it comes down to it
  8. Good deal if it falls thru lmk, Dave from Allentown PA
  9. I’m game to test them if need be, she is almost ready for them
  10. Okay cool, I found some online but I want to order up a set ASAP! I’ll weld them in and 10GA is cool
  11. Just picked up a 90 4.0 4x4 auto, Dana 44... Needs a boat load of work but I’ve got it all going and ready! Shout out to MeanLemons for the hook up Stay tuned for the progress and pics Dave[emoji520]
  12. Sorry, do you have a price and what all they consist of?
  13. what about this one.. cheaper but not all "metal" https://www.mishimoto.com/1991-2001-jeep-cherokee-replacement-radiator.html
  14. lucky indeed! now take your bed off for me lol
  15. Ya i have D44, how did you get the right angle on the Drive shaft to weld them on? i was going to assemble the leafs with the drop brackets and put the perch under the spring, lower the jeep down and use a small jack to adjust the shaft angle and tack weld them in then ill use my stick welder with 7018? what do y'all thing?
  16. hey guys, so i decided to do a SOA conversion for the rear lift and i did some searching but I'm not 100% on what is needed. i got new 3 hole weld in perches new leafs so i will need new U-bolts http://www.rustysoffroad.com/rustys-dana-35-dana-44-u-bolts-hd-grade-8-each.html new strut mounts http://www.rustysoffroad.com/rusty-s-u-bolt-plates-mj-comanche.html am i missing anything or a picture of your set-up would be great Thanks Dave
  17. Wow! I want those seats!
  18. I recently got a 1990 Comanche with no exhaust, I looked for and O2 sensor.. where are they located? Thanks guys
