Everything posted by Amccutc21
I’ll check that out, thanks.
The leak is coming from an area that is not visible. I was trying to see if anyone has experienced a similar leak.
Finally got around to locating the leak in my 89. I have attached pictures to show where the water is running. I don’t believe the back glass is the culprit, as the leak would be right where the frame seals against the pinch weld and the water intrusion would be visible. But would else could it be against the back wall of the cab?
Unknown electrical components
Amccutc21 replied to Amccutc21's topic in MJ Tech: Modification and Repairs
Thanks! -
I don’t drive my 89 in the winter months to keep the salt off of it, but today I got a wild hair to open the door and check carpet for wetness due to the high amounts of rain we’ve had. Unfortunately, I found my driver side soaked. I spent the next hour stripping the interior, and while doing so, noticed the pictured yellow and gray boxes underneath the driver dash. The grayish clear box appears to say something about emission performance? Anyone have an idea what these are? Truck came out of NC, do they do emission testing there? Truck is an 89 4.0 5-speed 4x4. Feel free to chime in on common places for leaks on driver side floorboard. I’ve got baby powder down but I’ll take all the help I can get.
Looking for a stock black bumper, but would consider a westin for the right price.
ISO: Rear bumper in good to great condition. Located in WV. Willing to pay for shipping if seller is willing.
I have an extra rubber trim piece laying around if you end up needing one. Let me know.
https://www.ebay.com/i/121059797132?chn=ps Here is a link to purchase the Euramtec lights. Like mentioned above, they are a good alternative to the stock lights. They do require just a little trimming on the opening to fit, however.
Since this is an old post and I have a related issue, I don't feel bad hijacking this thread. I'm putting back my interior and can't remember if all 3 bolts on each side are the same length? I believe one anchor point on each side had a smaller bolt if I recall, is this correct? I didn't do a good job of organizing bolts as I was pulling and don't want to run the wrong size anchor bolt into the wrong location and deal with possible associated headaches.
good deal! You take any other parts off the truck?
Never knew such a thing existed! I will give it a try when I get home from work to see if I can get any response concerning this issue. Thanks!
There's no visible corrosion on the cables where they make contact with the terminals. Any other place I should be checking for corrosion?
Went to move my project truck today and like the title says, I was unable to get it started. The truck is a 1992 with a 4.0 and 330,xxx on the dash. I moved the truck several months ago, and had to jump it then. Today, I hooked it up to my other truck from the start and it turned over, would click, but wouldn’t charge enough to come close to starting it. I pulled the battery, and put in a good battery from my other comanche and got NOTHING. Dash lights come on, but will not turn over whatsoever. Not a battery issue obviously. When the key was turned on accessory, I heard a repetitive clicking noise from around the fuse box. Thinking it was the starter, I got underneath and tapped it a few times but still had nothing when I went to start it, but the clicking seemed to have gone away. The key will pull out of the ignition when on accessory, and turn back without the key in it which obviously isn’t supposed to happen, whether it’s related or not? Also, not sure if it’s related, but I have started the process of removing the bed and have heard of issues of no starts after people have done this. Any help is appreciated before I start throwing parts at it.
I’ve found a rust-free long bed in North Carolina for $300, roughly 6 hours away for me. Would like to find something closer, but as you said, that might be difficult. I’d like a clean(ish) bed to put on and bob my existing bed that is damaged. Really needs the whole bed behind the rear tires replaced to be straight again.
Looking for a long bed to replace the current bed on my 92 that has damage to the driver side. Must be within 4 hours of 26508. Bed must be in good condition overall. Will accept a little rust over wheel well as long as it does not extend too far up. Thanks!
Off subject, but would you sell that white tailgate? I assume you are close to Morgantown, WV?
Been cleaning out and tracking down leaks (which are very apparent with the amount of rain recently on the east coast) on my 92. I noticed the PO had placed silicone around the top of the rear glass, which gave me a pretty good indication it leaked. I was taking care of some other things on the truck when I noticed that the rear window actually separates from the body as I shut the door, and can actually be pushed out at the top by hand. I can't imagine this is a common issue, but I could be wrong. Without taking it out, I'm struggling to grasp the idea of how these windows are supposed to seal. Is it the rubber trim that surrounds the window that seals? If so, and if i need to find another gasket, are they interchangeable from a solid window to a slider? The rubber gasket on the outside of the truck looks to be in good condition, but the inside looks rough. I have a glass guy coming to look at it tomorrow, but if this is something that can be tackled by myself, id rather put the $100 elsewhere in the truck. If pictures need to be taken in order for proper advice, let me know.
Thanks. I've seen those before and they are a little more than I want to spend. Also, the bottom cover may work, but the top will not due to having headrests
ISO grey lower cover for a 1992 bench seat. Must be in good condition. Shipped to 26508.
Gotta quit buying these things..
As appealing as that sounds, I think I’ll pass 😝 however, if you end up having any bed left behind the driver side wheel well I might be interested! -
Sounds like you did pretty well yourself! -
Martinsburg is where my first and current 89 Comanche came from, its a Pioneer SWB 4.0 4wd 5-speed with a factory Dana 44. Got it off the second owner and came with all original documentation showing it from NC. I've seen several others in that area since, along with parts, but really hate the drive I picked it up for $300 though. I've owned 5 within the last year, and this is by far the cheapest, and is better in some ways, than the others I've owned. I wish it wasn't a LWB but its hard to go wrong with a running and driving 4wd comanche with a clean title for that price! How much did that bed run you? SWB or LWB? This 92 had some damage behind the driver side rear wheel well and got into where the tail light mounts. I would like to EVENTUALLY address it. -
Thanks Wahoo! Found it on Facebook Marketplace and picked it up in Winchester. -
Thanks! I will shoot them a message.
