The tank worked really well for a while, it's just that a couple of the roads I drive everyday have buckled so I caught a little air and I think that might've cracked the tank. It only holds 4-5 gallons right now (everything else leaks out), but that's enough to get me from point a to point b if needed while I'm waiting for the new tank.
Thanks for the offer! There's always a need for spare parts, haha. I'll probly start accumulating a parts list this spring when I start working on the MJ again. Do you have any plans for the AX15?
Sounds like that longbed'll be a pretty beastly truck, if you ever need an extra hand workin on the MJ just give me a shout!
x2,
it's also not the best idea to drive with just one rear shock hooked up (@$$-u-ming you used the XJ shock mounts, which are staggered ft & back).
I ran like this for a year, or so with an MJ, but it's not good for the leafs, the leaf bushings, or suspension travel.
Good luck with your build. :cheers:
A buddy of mine helped me swap the MJ mounts to the XJ axle before we put it in (since I'm no good at welding) so the springs, perches, and shock mounts are all MJ. Thankfully he had the idea of doing that otherwise I would probly have destroyed the leaf springs. I did blow a shock (overextended an autozone shock cuz it was shorter than they said it was :doh: ) and riding with only one shock definitely makes for a really bouncy ride, got new Pro Comp's on there now tho.
Thanks for the advice guys!
