Everything posted by STERLING STINGER
how do you delete "your posts"?
STERLING STINGER replied to STERLING STINGER's topic in Forum Issues, Ideas, Testing
i don't know where to start little confused -
no....where you click "view your posts" i can't find edit anywhere, where is it. -
bed cover instructions??
STERLING STINGER replied to STERLING STINGER's topic in MJ Tech: Modification and Repairs
nope it has 6590 written on the inside of the cover -
i have this bed cover and have no instructions with it anyone got anything???? thanx in advance :bowdown:
cant access my real account
STERLING STINGER replied to STERLING STING's topic in Forum Issues, Ideas, Testing
got it thanks!!!! -
this problem happened last year also, so i got my radiator and water pump replaced first, i got in my truck and drove about 2 miles at 5am, and my thermostat was on the red...and no heat i took it home and used my white truck to go pick up my worker. i loosened my thermostat cover to see if it was bad and the heat started working, so i tightened it back up, filled with fluid, and went off for my day of plowing. before anyone answers that i was driving with the plow down and tilted so air was getting to the motor stop right there.....give me a little credit!!!!! i plowed like 5 hours and then all of a sudden.....yep, no heat and temp very high brought it to my mechanic just to work on it myself in his garage....in case i couldnt fix it i could just of left it there. like i said, he replaced my water pump and radiator in the summer, brand new well after it cooled down, i removed the thermostat and it was stuck open from the heat, but there was no fluids in the motor, (behind the thermostat) so i put cold water over the thermo to close it and put it back on. added fluid, then nothing after adding fluid and feeling hoses to see if they have anything in them for like 1/2 hour...the heat kicked on and everything went back to normal. it took like 5X of starting the truck until the antifreeze started to go into the motor. could this have anything to do with putting it into and taking it out of 4X4? cuz i was doing that all day i don't know this happened last year...thats y i got the pump & radiator replaced!@!!!!!!!!!
yseterday was my first real first plowing of this winter......lets see.... first, i got in my truck and drove about 2 miles at 5am, and my thermostat was on the red...and no heat i took it home and used my white truck to go pick up my worker. i loosened my thermostat cover to see if it was bad and the heat started working, so i tightened it back up, filled with fluid, and went off for my day of plowing. before anyone answers that i was driving with the plow up so no air was getting to the motor stop right there.....give me a little credit!!!!! i plowed like 5 hours and then all of a sudden.....yep, no heat and temp very high brought it to my mechanic just to work on it myself in his garage....in case i couldnt fix it i could just of left it there. he was all like, its your head gasket or water pump. he replaced my water pump and radiator in the summer, brand new well after it cooled down, i removed the thermostat and it was stuck open from the heat, but there was no fluids in the motor, (behind the thermostat) so i put cold water over the thermo to close it and put it back on. added fluid, then nothing after adding fluid and feeling hoses to see if they have anything in them for like 1/2 hour...the heat kicked on and everything went back to normal. no idea, i am going to post this in the question forum also. on my way home, i noticed that one plow light was out.....sucks bad THEN>>>>>>> i go to put up my window, drivers side, and it shattered.....good thing for the tint to kind of hold it together, inside the door. back to plowing. by this time its dark and I'm beat and pi$$3d i get home and notice that not one person in my development had their driveways powed......expect me to do it for free....its ok cuz they are all ancient and bring me cakes and great foor all year.....so i plowed them, pulled my poor truck in the garage and went to bed. CRAPPY DAY!!!!! :doh: :rant: :fs1: :mad: :headpop: :rant:
New member long time jeep owner
STERLING STINGER replied to saabflyer's topic in MJ Tech: Modification and Repairs
Welcome :cheers: -
mj no power....help please!!!!!
it seems to shift a lot better now it still bogs a little, but it downshift at a diffrent time than before......alot earlier thanks again....man i was looking for that part for like 20 mins before i got fed up and took a pic. that site really didnt give you the location of the part.......and I'm a noob, remember? lol all my cabels down there looked loose and crappy so I'm gonna put in new ones it looks pretty easy -
you guys RULE!!!!!!!! :banana: :clapping: :cheers: :bowdown: -
how do i get truck specs?
whatever specs everyone keeps asking me for when i ask a question -
it dosent have my year there 92 -
can anyone tell me how to get the specs on my trucks so there is no more confusion when i ask questions the 92 has plates inside the door and 2 on the firewall the 88 has plates that i really can't read can't you use the vin # or something? thanks in advance :bowdown:
i don't think thats my truck on that link if it is, there is no part like that on my truck the truck with no power is an 88 laredo with a 4.0 automatic there is also a transmission button on the dash, i think it kicks it to a lower gear ratio or something??? here's a pic of my throttle :redX: -
tundra cover installation
A leather cover that goes over the bed -
in my 92 i changed the oil, plugs, wires, filters i greased everthing i could see i ordered a mp3 player for it i cleaned it......again in my 88 i just got it back with new leafs and coils today :banana: flushed plow fluid put plow on to make sure everythings running good, it was fixed tail light cleaned interior noob, i know :shake:
any ideas how to adjust tranny kick down? -
any dvice how to check or repair? -
i have a mint tundra cover with no instructions i think you need to be a rocket scientist or something to install this :wall: does anyone have any instalation book or any info thanks in advance :bowdown:
My Comanche Project.....NOOBIE
STERLING STINGER replied to STERLING STINGER's topic in Member Projects: Your Comanches
is that photoshopped or something? my white one is my "daily driver" i was going to put 30s on it but I'm just going with the ones on the work truck, bfg 225/75/15 they lasted like 2 years now and theres a ton of meat left plus they are cheaper and look good -
brand new entire exhaust system it was rotted out so i replaced it like a year ago -
sorry about that, i just called lowes and had the guy on the phone with the tape measure....it will fit perfect the top where it sits on the bed is 60", which is a perfect fit the only thing is that it tapers down to 32" at the bottom and it is 12" wide i think I'm putting my tundra cover on instead.!!! sorry for the confusion :rant:
i was looking at your pic saying to myself, "when did i take that pic? and where the hell is that??" lol :rotf:
