Everything posted by keeponjeepn
Bucking under acceleration.
keeponjeepn replied to keeponjeepn's topic in MJ Tech: Modification and Repairs
Well ring gear it is. Pulled diff. 3 teeth broke off -
Ive been all under it. Fluids all good. Diffs,trans,tcase. It just recently started to clunk here and there while bucking. All u joints are good. -
I have 89 mj 4.0 ax15 4x4. The motor runs fine. Under acceleration it is bucking and making a "waaa waaa" noise? Best way to describe it. It sounds like its coming from under neath me or rear of truck." It feels like my ring gears are oval shaped" if you could imagine how that would drive. It happens more at low rpms 1500 or under. If i put my foot into the pedal it feels a little more smooth. Just looking to b pointed in the right direction?
Ebay- Mj Lund Visor $350
keeponjeepn replied to 88whitemanche's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
You still have the visor? Mj or xj? -
ba10 to ax15 troubles
If i use the cj pilot bushing do i only use the bushing and not the actual bearing?- 22 replies
Also i have the ax15 bellhousing internal. I no i should convert to the external but at this time i am very limited to cash for this. My truck originaly had an internal slave with the ba10. Can i use the ax15 internal bellhousing on this ax15- 22 replies
I got a brand new luk pro gold clutch from my buddy pretty cheap. Do i need to change out the flywheel for this tranny swap. And will my crankshaft sensor in my truck work- 22 replies
Ok so its because my truck had the ba10. Theres one hole top center on my ba10 sheild. No hole in ax15 bellhousing but i got it on the truck now. Srry guys this is my first project jeep- 22 replies
did they make the ax15 for the 258 motor- 22 replies
i will try to post a pic up early tomorrow of it sitting on the motor- 22 replies
this is the bellhousing that is from the ax15 that doesnt line up correctley- 22 replies
how do i post up a picture on this- 22 replies
as far as i no that is the bellhousing i have. 94+ external slave. . there is just one bolt that doesnt line up. and also do i need to change the crankshaft sensor- 22 replies
yea pulled the ba 10 out of the truck last week. tryd to line up the bellhousing that came with the ax15 i bought there is a bolt or 2 that just won't line up- 22 replies
i am new hear. just checkn to see if anyone knows if i need to change the inspection plate when goin from ba10 to ax15 transmission? also would a bellhousing from a 87 to 93 wrangler ax15 4.0 work with my 89 comanche 4.0.. the current bellhousing i have is from a 94+ ax15 external slave. but it doesnt line up 100% to the bolt holes on my motor. any help is apreciated
- 22 replies
