bheath
Everything posted by bheath
  1. Well, been working on my tail lights today. Purchased a headlight restor kit to sand/polish a second set of tail lights but it didn't work as I had hoped. Instead, I cleaned, buffed then just sprayed clear coat and they actually turned out decent. Also reconnected the ground behind the light with a new eye crimp and heat shrink cause the PO's other crimp was crap. The wire was moving around in the crimp so I know it couldn't have been a good connection. Now, I'm working on getting my reverse lights to work... I'll post some pictures in a bit.
  2. Well, this is my intro post and the start of my build thread. My name is Brent and I'm a jeepaholic. I'm not new to jeeps as this is my 3rd that I've owned and the 4th in the family. First jeep was owned by my father back in the early 2000's. It was a 1992 XJ 2wd 4door. It had around 250,000 miles when the speedo quit, therefor the odometer stopped working and we had no idea how many miles it actually had after that. We kept it for a while then regretfully sold it. Second jeep was a 1999 XJ 4wd 4door. I still have this one, it's my crawler/trail beater/trailer queen. I'll post more about it later. Third was a 2005 WK 5.7hemi. I bought it to tow my XJ with and for a DD. It was a fantastic vehicle to the motor gave up at 136,000... Sold. Now we have the MJ. I purchased this beast on Sep 6th 2015 from a guy about an hour away from me. Plans are to treat it with respect and restore and clean the truck to use as a DD. I have no plans to lift and offroad it due to I have the XJ for that and I need a solid DD. Specs: 1988 4.0 183,000miles 5speed 2wd shortbed Most everything on the truck is factory although I have noticed somethings have been replaced. I'm not sure what # owner I am but I think either 3rd or 4th. The truck had some issues when purchased of course, first thing I noticed was surging at idle until it was drove and warmed up, second was an oil leak from the pan (according to the PO) that dripped on the exhaust, then there were the obvious things, paint is crap, couple dents and holes in the body, underside was covered in grime from the oil leak, headliner had been taken out and carpet was long gone... On the plus side, It has a new valve cover gasket, battery, cables and starter. New radiator for a newer model xj (according to PO) and an updated cooling system (according to PO). Floor pans have had the rust cut out and has been patched by the PO and rolled with what looks to be cheap bedliner. Bluetooth radio with some crap speakers behind the seat and a decent set of rubbers. Black interior with a freshly reupholstered bench seat in naugahyde. So far I have eliminated the c101 connector, freshened up the grounds (i have cable and stuff to replace some of them and do the standard ground add-on's), replaced the oil pan gasket (which made the leak alot worse), went through all the plugs under the hood and truck and cleaned and greased, gave it a well needed bath, changed oil and filter, inspected the entire thing from top to bottom, greased all the zerk fittings, and cleaned the interior. I'm sure I'm forgetting stuff but if you are still reading at this point, you either have no life or are a true champion. I will be posting pictures when I have the chance although I have come to find out that posting pictures to this site is a pain to say the least. Some will be with my phone and some with my camera. but for now you only get a couple outside pictures. I'll post more tomorrow.
