asm4mcc
Everything posted by asm4mcc
I HAVE A 9K AND YES THE MORE CABLE UNRAPPED THE PULLIN POWER AND THE CABLE WINES UP THE LESS PULLIN POWER THATS WHY YOU USE A SNATCH BLOCK SO U CAN PULL MORE CABLE OUT ITS LEES STRAIN ON THE WINCH
I FOUND SOME ONE EBAY BUT I WOULD LIKE TO HAVE IT FOR THE WEEKEND. BESIDE A DEALER IS THERE ANY STORES THAT CARRY IT?
ok i got a new tranny mount but i need the bracket does anyone know where i get one beside a junk yard and what is it call ? thank you
oh crap ok yea i now saw you told me that ok thanks alot
instead ff swaping an h/o just gear it its not like you loss the power its still there you jus need to gear to get that power to the tires
i just throw a strap around the shackle, do it all the time , but i did see my buddys shackle get ripped right off but he was in mudd up the the middle of the door and the kid pulled from the side instead of from behind him
what motor do i use 3.8 or 4.2
k thank you
i would take a pick but it dark out and the trans is outside and i don't even kno if i have a camera anymore. if i do i don't kno where its at ok well i was looking around on the internet and i found some info that i need it from a cj 5. but from like 70-76 and 76-79 there are to diff busing for them to sets of year so i kno what year i need the early 70 or like 78.
i don't have the tool to measure it so i get went out side and checked to see if the bushing would fit onto the tranny but it won't slide on. what year and what cj and engine do i need to get it from?
man this sucks i really want to get this tranny in this weekend but i can't find anything on what bushing i need if anyone can help i will be very greatful thank you
ax 15 like 97 and i just went down to advanved auto today and i had the kid look throw all of the cjs and motors couldn't find the one i needed
if the mj bench and bucket are the same then how do u make it work with a xj seat
it was like 2.99 i guess ill jus take the clutch tool with me no the id of the bushing
no
i got the flywheel on put the cj piolet bushing in but the clutch alinement tool won't fit in side the bushing so i guess its the wrong on does any one know what bushing i need the one i put in is froma cj i forget what year and motor i told the guy at auto advanved
ok well i got that bushing for a cj since they changed the crank end size or something but the end of the tranny won't fit inside the bushing so i guess its the wrong one and what is the trick to get that bushing out
i need diamentions of mt flywheel bolts
i want comanche buckets or just the mounts thankyou
is there any where i can fine torque specs for:flywheel bolts ,pressure plate things like that
89 mj swaping from at to mt i got the new flywheel can i use the same bolts bolts or they goin to be longer and are the starters the same
ok if i get a dana 30 from a cj and get the outter part of the axle and all the parts for the locking hub system will that bolt up to my 96 dana 30 thank you
sunday i put my clutch pedal and drilled holes and put the clutch master clinder in. this weekend I'm goin to swap the tranny in. also i just ordered a new carrier and 4.88 for the dana 30 and 4.88 for the fored 8.8 will post some pics
i picked up a dana 30 today and sanded it and painted it and also order 4.88 gears for the dana 30 with a new carrier and also 4.88 for the for 8.8 with master intall kits tomorrow I'm gonna pull the tranny out and maybe put the diff dana in
i just picked my flywheel up and got everythingelse i need so once this weather gets a little warmer I'm gonna start puting in the tranny but this weekend i got to go to harys you pull it for a dana 30 mine blow out and the wheel bearings are bad and also the ball joints are bad so it will be cheat to go get a diff rear
