asm4mcc
Everything posted by asm4mcc
  1. what dana 30 front rears can i use that will bolt right up? what jeeps? what years?
  2. i am swap my 89 4.0 4x4 mj auto tranny with a 96 ax 15 what do i got to do for wiring the ax 15 tranny ? what do i need to get ? thanks for the help
  3. can any one help me with what i got to do with the wiring for the 5speed
  4. does anyone knows or have a link for a post on antidisestablishmentarianism i got to get and do to wire my ax 15 in my mj
  5. whats even involed ? what do i need to all get?
  6. yea I'm gonna pick a fly wheel this friday it would be nice if you could help me fine info on that 5 speed harness what do i do just search the post for 5 speed harness
  7. ok well that makes things harder i hope there is a post how to do that cause that sounds a little hard
  8. ok thanks so all the plugs and wiring from the auto with match with the ax 15
  9. i have one more think to ask about and then i should have all the info i need for the swap i also want to get a steering column from a 5 speed 87-90 jeep is there anything i need to get with the column for the swap such as connections or wiring harness?? :clapping: thanks again for everyones help
  10. so i ordered my clutch kit and cj bushing i will pick it up tomorrow after work and then on friday i will buy a flywheel and sat ill go get the clutch mc and pedal ,steering column and hopeful we get some nice weather this weekend so i can put the tranny in the mj
  11. with the tranny the slave is on there but i need to get the clutch kit it comes with everything i need it Contains Clutch Disc, Cover Assembly, Release Bearing, Pilot Bearing/Bushing & Alignment Tool; Cover Type: Raised Diaph.; 10.4x10Tx1 1/8 I'm not sure what else there is i never messed with an mt tranny
  12. ok thanks so let me get the right ill buy a clutch for a 96 and one part for a cj that cost $2 and then i can put the clutch in then i got get pedal and master c fly wheel and cross member then put it in the mj ?? sounds good to me well what about wiring?? and i kno i probly keep asking some of the same things but i just want to make sure i have everything i need and i appreciate everyones help
  13. i was thinking i probly def need a part number becuase theres probly diff engines and years for the cj part and if there is any other parts for the clutch i need if i can get the part number for it would be great
  14. ok thank you so when i go to the auto parts store i will buy a clutch for a 96 and does anyone have the parts number ill need for the other part i must get
  15. well can i just buy a clutch for a 89 with everything
  16. how do i know what pilot i need i was gonna buy a clutch kit that came with everyting for a 96
  17. ok i got the things i needed to kno now ill go get what i need and post in a little while thats not a rear coil thats a breather hose
  18. ok thanks everyone yous were very helpful i got ax 15 and tc , now i just got to go get a 87-90 mc and pedal,87-90 flywheel and an ax 15 cross member ... are the cps the same for auto and and mt.....also if i am missing anything please let me know. thank you
  19. ok thanks but i should buy the clutch for the year tranny i have right? and will it make a diff what year i get the master cyclender and pedals froms? one more thing are the bell housings the ame for the renix and ho motor?
  20. thanks i read that thread but it didnt see the info i need but maybe i missed it well i just want to kno when i buy the clutch I'm thinking i should buy it for a 96 since thats the year the tranny and tc are from this clutch kit comes with Clutch Disc, Cover Assembly, Release Bearing, Pilot Bearing/Bushing & Alignment Tool; Cover Type: Raised Diaph.; 10.4x10Tx1 1/8 also I'm guessing the flywheels are diff between atuo and stick ? also with my mj bein a 89 and the tranny coming from a 96 will the bell housing be the same? and one more thing should i get the pedals and master c from 89 or 96 thank you for the help
  21. i got an auto tranny and i got the ax 15 and tc out of any 96 the clutch i looked at was from advanced auto Clutch Set; Contains Clutch Disc, Cover Assembly, Release Bearing, Pilot Bearing/Bushing & Alignment Tool; Cover Type: Raised Diaph.; 10.4x10Tx1 1/ so all i need is the pedals, master cyclender and a fly wheel from a 5 speed(but do i get the fly wheel from a renix or ho motor
  22. the bumpers are designed in Auto Cad by Logans Metal Products its was like $300 or 350 my next thing is i want to put in a 5 speed but not sure if an ax 15 from a 96 will and what ill all need i put a post up so u guess i just got to wait to see if anyone can help me
  23. yea in the front i got the 8.5-9 inch coil with 3inch coil spacer i did have only a 2 inch spacer but from the weight of the bumper and winch i had to add an inch to level it with the bak and in the back i fliped the rear witch gives around 4.5 to 5 then a 3 inch steel block and a set of shackels i tryed posting pics but i didnt figure it out so if anyone can help me i would gladly post them
  24. hi i asked these questions but i put it in the mj project sorry i am gonna try to make my auto mj a 5speed mj is a 89 4.0 4x4 i got a 96 ax 15 tranny and t case to go with it. i kno i need a master clinder and the pedals. i also want to switch out the steering column. but I'm not sure what else i got to do like will i need to do anything about the bell house since i got and older 4.0 and the ax 15 is from an high output motor and what about the plugs on the tranny and some of the other wires. also do i need to chnge the flywheel thank you for your help
