skigots
Everything posted by skigots
Radiator had split down the side. Put in a new one and 2 days later the water pump locked up🤬 all is good now and its running like a top
Finally got to use it last night. Worked out great and was very stable. Got an unexpected rain storm through the night and everything stayed dry. On the way home the xj overheated. It was pouring steam out from under the hood🙃 was able to limp it home but it sounded terrible
Picked up a spare tire mount at Lowe’s yesterday. Got bored so i went ahead and mounted it in the rain. Lol I think it turned out alright.
Thanks! I’ve wanting to do it for years and finally bit the bullet. The tent I actually got a pretty good deal on. Caught it on sale on amazon and got it for $800
Finally made a little more progress. Got my low pro rack delivered and received the tent a few weeks back. Was able to get off early enough to put it all together.
The Alabama Turbo Diesel
skigots replied to ThreeComanches's topic in Member Projects: Your Comanches
Good luck -
Wheels came in today while i was at work! Matched the ones on the xj perfectly. Hopefully i can get them mounted this week
I’ll be posting more pics soon. Wheels to match xj are being delivered tomorrow and rtt should be arriving next week
Nice trailer. I’m mostly done with mine or at least I would like to think I am
Factory lighting was all screwed up and I wanted something different
Been working on this trailer build little by little for a few months. Started as a ‘88 sportruck i got in high school from my grandpa. Drove it for 8 years until the block cracked behind the water pump. Couldn’t convince myself to put a motor in it when I already had a nicer xj, so i started cutting. Took a lot of things off and added a few back on but this is where i am at so far.
Curious to see where this goes. Good luck to you
Love the build so far. Makes me wanna lift mine :thumbsup:
1988 comanche sportruck 4wd swap
skigots replied to skigots's topic in MJ Tech: Modification and Repairs
trans and TC from 2.8 would work??? if so he has one of those as well -
Alright cool. thanks for all the help. Looks like its gonna take even longer than originally thought. will update when possible -
would the bell housing from the 4 speed fit on the auto??? -
He also said i could have the 4.0 if i wanted it. How much work will need to be done to make it work??? What all will i need??? -
ok thanks. Ive got a NP231 and a Dana 30 front. what transmission should i look for??? -
P.S. the trans and transfer case are from a 4.0 auto. would it bolt right up??? -
Hi, My name is Sam and i'm new to this forum. I've got a 1988 Comanche Sportruck with a 2.5 and a 4 speed. A friend of mine said i could have the axle out of one of his Cherokees along with the transmission and transfer case. What else would I need to make it 4wd??? I'm on a budget so I don't want to spend to much money. This is going to be a slow build. Any and all help is appreciated:)
