Minion33088
Everything posted by Minion33088
  1. You guys saw these 236 pictures right??? https://m.facebook.com/Comancheclub/albums/10151139085403135/
  2. Well I hope no one wants bench seat covers...they lost the patterns (dimensions) for them... ;(
  3. Has anyone else here ordered a bench seat cover? The lady that took over can't find them in the system and asked if I had a previous order number. If anyone has ordered one in the past, can you help me out and check your email for an order number?
  4. Dave, I suppose you are no longer with the company? I sent you an email today but I got an auto response for a new point of contact.
  5. One thing that I noticed was missing from this write up is the MJ tail light wiring, does anyone have a diagram or write up on how to splice in the MJ tails?
  6. Ripped the bench seat and carpet out for a nice surprise today. Not too bad, it shouldn't be too bad to patch. Looks like my XJ will also be donating some floor panels lol
  7. Maybe for the worlds fastest MJ you need the worlds most powerful 4.0. 693hp!!! Read here: http://www.fourwheeler.com/how-to/engine/154-1001-insane-inline-ii-part-2/
  8. Well I started alittle later than I had hoped but my Renix MJ has fired for the last time...got everything set up to get tore down this weekend. Basement all cleaned up and MJ and donor XJ parked side by side. Started tearing the truck apart after work today, got a good amount done for the time I had. LOTS more to do, but I'm happy to finally start tearing into it!
  9. I'm running a 7" lift and a narrow driveshaft. I was measuring under there earlier I think it will fit but my 8.8 is alittle on the large side.
  10. Shelby, you put your TJ tank where your MJ tank was right?
  11. XJ tank won't fit where the spare I without sticking down 13 inches or more. Would need a good skid and ruin you departure angle.
  12. Do the TJ tank swap, you can find them for a good price if you keep your eyes open.
  13. Yeah I read that, I'm gunna cut the tube so I have more capacity.
  14. Shelby I'm reading up on TJ tanks and it seems they are supposed to say 'E' when you still have a few gallons left so you don't run out of gas.
  15. Ok cool, thanks guys. I will test the fuel levels with the xj gauge and if I'm not happy with it I'll fix it with a tj cluster.
  16. Ok I got a TJ tank and sender from a friend for $20. :) I have been researching tj)xj gauge clusters and it looks as though alot if people are swapping tj to xj and xj to tj and not a single person has said anything about the gas gauge bring off. Does someone have actual experience with the gauge being wrong?
  17. Ok, thanks dude. I've had both apart and I think the plugs in the back matched
  18. Tj cluster should be plug and play right?
  19. Why do you need to swap in a TJ gauge cluster? How far off will an XJ gas gauge be with a TJ tank anf sender?
  20. Lol nice. Well I think I'm gunna get alittle creative with my xj tank, I got ride of my TJ parts and any Dakota tank at my junkyard will have a hole in it (they drain the gas)
  21. Well $150 that sucks, I can buy a tj tank for that lol. How did you deal with the filler neck hoses attaching in a different spot? Can I put an XJ sender in a tj tank?
  22. My MJ tank is brand new I'd like to use it but I can't find any of those mounting rings
  23. I was thinking that..but then there's the filler neck issue..
  24. Will a whole tj tank fit? Can I put my XJ pump/sender into a TJ tank?
