88minibitch
3 Followers
    ohio
88minibitch's Achievements
  1. Hey tugalo I used brake cleaner and cleaned my whole fuse box and the c101 followed with compressed air,, worked fine..
  2. I cleaned the c101 when I cleaned the fuse box.. I just put the New cps on and I've still got the same problem,, no power!! I don't see a ground near the e.b. at all can I just run a new one?? If so just tell me how I like to learn..
  3. I'm sorry it does bolt in,, there was so much gunk on them I couldn't see them.. I ordered a new cps and I'm going to put it on today.. as far as the ground,, I probably need to check the one under the dash because I may have damaged it when I was changing the master cylinder.. Tight spaces and big hands don't go together.. Lol
  4. yeah i re-connected it,, but it doesnt bolt to the bell housing,, it just cliped in.. i just used a fuse light and i have a green light to all the parts that arent working.. the fuel pump is getting power and so are all the lights.. even double checked the fuse box.. did realize that when i mounted the tranny i have a flat ground mashed between the motor and tranny,, but i don't see where that would be a problem..
  5. hey guys I'm new to jeeps all together,, my dad gave me an 88 comanche and hes been lots of fun till now.. i was on my way to work when my clutch pedal sank,, turns out the clutch master cylinder went bad,, i changed it and refilled the lines only to have it gushing from the bottom.. it was running at this point!! had to change the slave cylinder,, after we put the tranny back together and connected everything in getting no juice!! the only thing electrical working now is the seatbelt lamp and buzzer.. i had the starter tested,, its good.. i took the fuse box apart and cleaned all the break fluid out of it and put it back together with new fuses.. is it possible it could be the starter relay?? when i hit the key it cranks,, I'm just not getting any fuel.. no head lights,, wipers,, tail lights,, radio,, signals,, hazzards.. everything electrical is out!! help a girl get this fixed.. :)
