jeeping88
    CT
  • Interests
    Jeeps, wrenching, dirt bikes, anything with engine.
jeeping88's Achievements
  1. Mercedes om617 I just put in my '88 manche. Haven't driven yet, need to make driveshafts. Adapter to ax15 from mercedes4x4.com and my own mounts
  2. Hey, 91dieseljeep, I just did same swap got it running tonight. The engine shakes whole truck...alot! How much does yours shake and rattle? Thanks
  3. You get some good practice while doing intricate welding like that.
  4. You could use a easy out if broken part is flat and pin punch hole first. Or in my personal experience if you have a welder, you can weld a nut to the broken bolt and the heating/cooling of the bolt most likely will spin right out
