Jacob Ochs
Everything posted by Jacob Ochs
  1. Anyone selling a MJ Cab Roof? I’ll pay for shipping and whatever you want for the part! Sent from my iPhone using Tapatalk
  2. Here is the first test drive with the turbo! Sent from my iPhone using Tapatalk
  3. Here was the accident I was in in the Jeep back in July, the area I live in was flooded and the road collapsed under a train trussel I was unaware of. The department of transportation in my state had cleared all roads safe to drive in that area! Long story short it flipped and I had to jump out mid flip [emoji50] Not a fun day! Here are the results: I think the Cosmetic Rollbar Coated with Line- X saved the back side of the cab and the rear window! I’m waiting for more Jeep funds to get the body work redone! Advice to fix a Waterlogged 4.0L After the accident I drained all of the fluids from everything that could hold fluid and filled them with Diesel, including taking the plugs out and filling the cylinders with diesel. Differentials I filled with 10/30. After being pissed off for a month, I drained all of the diesel and put the proper fluids back in (including differentials) The Jeep started right up with new plugs, the only thing that needed replaced was the throttle positioning sensor. Random things stop working daily, mostly electrical. I’m recently having a fuel cut out problem and the CEL came on. I’m sure I will continue to have issues until everything gets slowly replaced! Sorry for the long post, I haven’t been on here in some time! Sent from my iPhone using Tapatalk
  4. Thanks Pete! [emoji4] here is the most recent picture of the Turbo setup! I’ll have a video here soon. I need to upload it to Youtube in order to post it here! Sent from my iPhone using Tapatalk
  5. I’m finally able to get back into my account! The Comanche is now half way turbo charged [emoji28] Sent from my iPhone using Tapatalk
  6. Hit me up if you do, I’d love to buy them! Sent from my iPhone using Tapatalk
  7. Hello, I was wondering if anyone had a driver and passenger side exterior door trim set? I have a picture of the parts I need. Sent from my iPhone using Tapatalk
  8. I was wondering if anyone had or knew where to get the trim circled in red? Mine is missing. Sent from my iPhone using Tapatalk
  9. Here’s a walk around video I did before the weather gets nasty!! Check it out!!! Sent from my iPhone using Tapatalk
  10. More pictures! Toolbox texture powder coated and spare tire carrier added! [emoji106][emoji106] Sent from my iPhone using Tapatalk
  11. More pictures! Interior included. I’ve been looking at Nate’s 4X4 rock sliders and think I’m going to be purchasing them soon! [emoji16] Sent from my iPhone using Tapatalk
  12. All back together again! Also took a chance to upgrade it a bit! Used the 1 1/4” chain from a full sized truck. Sent from my iPhone using Tapatalk
  13. Was simply going to replace my loose transfer case drive chain and decided that that was to easy and accidentally broke the output housing [emoji58] Should be running by the weekend! 🤞[emoji16] Sent from my iPhone using Tapatalk
  14. My cruise control has been working fine for the past year or so ever since I did my 86-96 swap on my MJ. Well about 6 months ago when I would press the cruise control on/off switch on the steering wheel the light wouldn’t come on at all. A week later it started working again. Now it is doing the same thing but hasn’t fixed itself unfortunately! I’ve checked all the check Valves and vacuum lines for leaks and I’m pulling good vacuum. Everything else works 100% correctly no blown fuses nothing! Any suggestions?? Sent from my iPhone using Tapatalk
  15. Here it is all completed! No write up because I was getting to pissed off while doing the build (as per usual), I’ll answer any questions though!! Sent from my iPhone using Tapatalk
  16. Going to be attempting the double din full screen head unit tomorrow (see pictures for the one I’m using) first I’m trying to clean up wires from being lazy wiring up some accessories! I’m doing this cause I’m directionally challenged and I wanted a head unit that had navigation. I also ordered a back up camera as well to go along with it. I’ll try to make a decent write up, I’ve not seen any good ones yet! I believe I’ll have to cut a little into the defrost plumbing, shouldn’t be a big deal [emoji1360] Sent from my iPhone using Tapatalk
  17. Quick funny story, so I installed some rock lights and reverse lights this past month and I kept smelling what seemed to be burnt rubber or plastic. I looked at all my wiring, everything was fine! Well the next time I drove it and looked under the vehicle I saw this sitting up against the exhaust! Good thing it was free from Harbor Freight. Sent from my iPhone using Tapatalk
  18. I’m looking into super or turbocharging my Jeep but I had a few questions. I have experience with megasquirt from a previous ending build and I don’t think I’ll ever go through that head ache again! I did see this however, it looks like a plug and play tuner for Cherokees! It says it only works with 97-01 Cherokees? What is the difference between the 96 and 97? Would I still be able to run this? https://splitsec.com/product/ftc1-201-fueltiming-calibrator-jtec-jeep-p-n-p/ Sent from my iPhone using Tapatalk
  19. So about a year ago I had noticed something different during my swap between the 86 and 96 Air box. The 86 had nothing and the 96 had a small box that went into the Housing of the condenser. I’m assuming that it controlled temperature? I’m not sure. I do know if it wasn’t plugged in the AC wouldn’t run though. So my question is, what is this thing (see picture) and how does it effect my climate! I currently have it zip ties under the dash but if needed I will drill a hole and put it back in the condenser housing! Sent from my iPhone using Tapatalk
  20. Line X complete including the roll bars! Also, forgot to show this in the first few pictures but my bodywork guy Mike shaved off the antenna mount and I tucked it under the fender well just to give the Jeep a cleaner look! Still picks up great! Sent from my iPhone using Tapatalk
  21. Thanks!! I’m gonna try that out today, that’d make things much easier! Sent from my iPhone using Tapatalk
  22. Here it is all painted! Sent from my iPhone using Tapatalk
  23. If you want more frequent updates and just pictures in general follow my Instagram page: Ochszy1 Sent from my iPhone using Tapatalk
