mpd.diesel
Everything posted by mpd.diesel
  1. Those drop brackets look like mine. I bought a 4" Rough Country lift about 4 years ago. I have mine all the way forward. No interference. Sent from my SAMSUNG-SM-G935A using Tapatalk
  2. Got the hood up. It was a combination of reaching up between belt driven and auxiliary fans to pull down on release rod. That took care of passenger side. Had to remove headlight and bucket to release the driver side... We got slammed by high winds, flash flooding and a tornado here in Arkansas yesterday so no time to diagnose truck wiring. We have been helping friends secure homes and clean up. I'll update later, it's back to work in the a.m. A sincere thank you to everyone who offered advice to help resolve the issue. Sent from my SAMSUNG-SM-G935A using Tapatalk
  3. Got it. Thank you. Sent from my SM-T350 using Tapatalk
  4. To be clear-The fusible link is still disconnected. It has to be non-critical to starting or charging I reckon. If I touch the ends together though it sparks so I know something ain't right on the other end. Well, I'm off to figure out how to raise the hood. Sent from my SAMSUNG-SM-G935A using Tapatalk
  5. It's definitely going to ground at the component. I'm going over the schematic to figure out which component that is; however, I went out to the truck to look and now the hood release cable I have so lovingly cared for since 2006 has broken and I can't raise the hood... I swear this thing has fought me every step of the way since I decided to place it back in service... (It has set for the last 2 years waiting on me to convert the cooling system.) Sent from my SAMSUNG-SM-G935A using Tapatalk
  6. My wiring is old and brittle. My truck battery shows 13 volts, but truck won't even try to turn over. Fuel pump comes on but that's all I get. Radio light goes out when I turn key to start position. The large red wire on this block goes to muy alternator and this green wire is broke. I'm assuming this ain't good. Any one able to tell me what this silver block the green wire and alternator wire are connected too does? Am guessing my issue could be here. Battery is only a month old. Sent from my SAMSUNG-SM-G935A using Tapatalk
  7. 4.5 RC lift TJ rims 33x12.50x15 BFF MT Sent from my SAMSUNG-SM-G935A using Tapatalk
  8. I just ordered one of these along with a replacement set of rc fixed lower c.a. for muy 87 mj. The bushing in my lca is sloppy and it headshakes real bad at about 35-40 mph. Hope the cure helps. Sent from my SAMSUNG-SM-G935A using Tapatalk
