TUFF-IRON
Everything posted by TUFF-IRON
  1. Thanks for the replies, and it may be blasphemy but the 327 in question is supposed to be a 1963 out of a corvette I have not verified that yet. The engine sounds very good and is allready installed in a 55 cj-5. And I am old enough to remember the amc 327Vigalante ,if I was restoring this MJ I would keep it 2wd and the 5spd that was in it. However it is being converted to 4wd I already have a set of axles with 410s almost ready to install . I am waiting on new control arm bushings and the front axle is ready,the rear is going to be a spring over so as soon as I get the spring pads relocated it will also be ready. At this point there is a couple of options I just thought it might be fun to do something different. :wrench:
  2. I was wondering if anyone has any info about swapping to a 327 ? Thanks for any advice my comanche is a 87 short bed 2wd , I have a set of axles with 410s and will be doing a spring over on the rear end. I have already removed the 5 spd , any advice would be appreciated Thanks
  3. Yell at her first and ask her why the hell she hit your truck :clapping: :wall: :fs1:
  4. Good job on a great find. I hope your conversion goes well :cheers:
  5. Thats a really nice truck ,good luck on your build Happy new year :cheers:
  6. Today I plan on removeing the 5spd ,bell housing ,clutch assy.and flywheel on the MJ , then its a lot of cleaning and I will probably replace rear main since its down that far. I found a 87 XJ with an auto and 231 to swap over ,have already pulled wiring harness for trans out of the xj and will begin that removal next, my friend has a matched set of 410s out of an 86 { no vaccum disconnect} he said I could have for this project the front is a d30 and the rear is a d35, I know its a lot of work to make the d35 fit but the price is right and they are in good shape. The spring over takes care of the lift in the rear,and the spring pads needs to be moved for the MJ anyways . Here goes wish me luck
  7. Thats the cleanest engine I have never seen!!!!!!!!! :huh???:
  8. Well today I bought a 87 XJ that has a good trans and transfer with much other usable stuff ,will try to post pics when it gets home and the conversion begins to make it 4wd
  9. You have the prayers from a lot of good people from all over . May she have a complete and speedy recovery ,stay strong and "GOD" Bless
  10. TUFF-IRON
    My MJ
    Thanks for the offer for the vaccum lines but I was able to raid a junk yard and find a fuel tank with a working pump as well as most of the missing caps and lines, I installed them all last weekend and the motor fired up and ran pretty good ,
  11. TUFF-IRON
    My MJ
    I live in Lake Havasu,Arizona the jeep has been in Az.for the last 10 years or so , that explanes the lack of rust. As far as the XJ axles thanks for the tip I will definately check before assembly begins.
  12. TUFF-IRON
    My MJ
    The previous owner had started to install a lift , changed his mind and pulled all the parts .He didnt bother to put in center bolts or even line up the spring leafs,he just pinched it together with the u bolts and halfassed bolted the front end back under the truck before he had it towed.I lucked out and my friend was the driver that picked it up,I bought from his boss as it sets.I was not worried about the springs or the front axle because I am going to change it to a spring over in the rear with XJ axle a spare set of MJ springs,yea I noticed but thanks for the reply :cheers:
  13. TUFF-IRON
    My MJ
    Hello everyone my name is Terry and here is some pics of my 87 Comanche it has a 4.0 and 5spd and its just 2wd however I have other plans in mind,hopefully it will soon have an aw4 with a 231T/C AND 410 axles under it. This weekend I was able to get it running after changing the gas tank,sending unit and pump and replacing all off the vaccum lines and fittings,the motor sounds pretty good now I can begin other changes. Here is the link for pics http://www.PictureTrail.com/gid21102576 let me know what you think Thanks :cheers:
  14. Hello everyone here is an update about my sending unit problem ,today I installed the new used tank assembly and once i got all of the vacum line hooked up correctly the motor fired up and ran pretty good now I can start on the conversion to 4 wheel drive and not worry about swapping the motor , Thanks again for your help :cheers:
  15. Thanks for the replies and suggestions everyone ,but today I got got lucky at a junk yard and found a complete fuel tank with a good sendind unit and pump with filler neck and it only cost me $50.00 so I can see if my Comanche runs :clapping:
  16. http://www.picturetrail.com/gallery :cheers:
  17. Hello :wall: everyone I was happy to find this site while looking for info on a "87" Comanche that i just picked up .I also own a "96" Cherokee ,my question is will a fuel sending unit from a XJ work in the MJ I know the fuel pump is supposed to be the same,Thanks for any info
