buddy208
Everything posted by buddy208
  1. what about the shock mounts
  2. would axle fit from a 94 cherokee or do i have to modify them. cause my leaf springs are 42' across and 55 in length and the cherokee is 43.5' across and 49 in length
  3. i thought someone on this website slap one in from a 2wd xj and it fit perfect.
  4. i heard that a 2wd drive shaft would work for a Comanche that is 4wd, is it true, if so would it work with 4 inchs of lift.
  5. what is the difference between normal 8.25 axle and 8.25 hd axle. ( and yes i know what hd means)? what a gas nozzle (where the gas cap screws on to) from acherokee work on a 89 mj? does 4 inch lift need different length arms? how much lift does the stock leaf springs give if you go under with the axle?
  6. does anyone have a fuel cell in their comanche
  7. where did you get your fuel tank
  8. do you know where i can get one
  9. does a cherokee gas tank fit into a comanche
  10. yea we hook up the rear harness the lights still did not work
  11. so how do i get a pump to work
  12. 1989 comanche 2.5l 4 cylinder 2wd to a 1994 cherokee 4.0l HO 4wd and i swap everything except the fuel pump, i tried today but the one from the cherokee did fit in the comanche it was block by something i think
  13. i just swap a 4cylinder 2wd to a 6cylinder 4wd from a 94 cherokee and i need to know how to do the fuel pump, do you just swap them or do you have to change the parts on one
  14. one more thing the brights come on but don't stay on
  15. i just swap every thing from a 94 cherokee to a 89 cherokee and we are working on the rear end wiring and when we hook everything up the head lights and brake lights did work can anyone tell me why or if it could be a fuse.
  16. thanks if it helps its on the very back corner of the diver side block
  17. how did you do the tail lights and gas tank wiring did you take the cherokee wiring or using your old wiring hook up and just spice the wires
  18. has anyone done this swap before if so what did you do about the wiring in the dash
  19. new question to run i took that 94 cherokee's drivetrain (engine,tranny,transfer case) and put in my 2wd comanche do i need the 94 interior wiring harness or can i keep my old one
  20. my comanche is a 89 and the cherokee dash is a 94
  21. has anyone changed there blue dash with the big fuel gauge to the new one with the rpm gauge and how did you connect it
  22. i broke this piece in half and need to know what it is to replace it. 94 cherokee 4.0l image as soon as i figure how to put it up again
  23. i was told there is a bracket for the altenator to place it where the a/c pump usually goes
  24. i think my back speakers are 4x6s
