k3rn4lkr45h
k3rn4lkr45h's Achievements
  1. you can keep the rear axle if you match the ratio for the new front axle.
  2. a thing of beauty an inspiration for my own
  3. good thing florida has no inspections ... :brows:
  4. oh russians....sneaking in with their bad english and trying to give everyone free viruses. who thought they would be so giving? :)
  5. not using battery back up? lol
  6. its a great diagnostic tool called UBCD, ultimate boot CD. it has tons of tools on it. you download it get it installed onto a USB. boot to usb and choose your Diaging choice. I would start with the Ram, under memtest 4.2 let it run for a couple passes. if nothing comes up red then your ram is good. then reboot to usb and go to HDD then Diag and select Seagate 2.0 usually finds most HDD Models then run extended test. do each drive individually plugged in. you will find you culprit. http://www.ultimatebootcd.com/
  7. hmmm maybe your chipset is going on the motherboard, if you have a usb or cd download UBCD and run diags on the HDD and Ram
  8. Sounds like the controller card on the HDD. It can halt the machine if shorting out the PSU.
  9. Hey there Comanche Club. Noobie here. Just wanted to start this as my Build Progresses. Few weeks back I Picked up this beauty an 88 4.0 shortbed Comanche for $1100. Besides the cancer i think she is pretty. Yes I Plow with her. The previous owner had already done some Mods, check out the interior Also Has the 4 inch lift and Nice tires. has the x15 tranny. Frame looks to have no rot surprising up this side of the east coast. Now only owned her for a few weeks and have had to do a break line, waterpump, thermostat and replaced a cracked housing around the water pump. I was going to wait for the warmer months to start my own build. then ther other day this happened.... So now i have the perfect excuse to start the build sooner :) on to the good stuff- What i plan to do first, Danna 44's Front and rear 3:55 ratio, rear disc breaks. Full Front Suspension Replacement Trackbar,Steering Stabalizer, Control Arms (poly Graphite bushings), Skyjacker Soft Rides, and of course Ball Joints. Convert from foot pedal to Custom Hand break. Also plan to rewire the cab as it looks as if it was not the previous owners forte ;) (fuse taps are bad mmkay, shorting out and being pulled out anytime you clutch) Thats it for the imediate project. After that is finished ill be getting new doors and ripping out the interior to check under those carpets for cancer. and replace the fenders. then I plan to Rhino Line the whole truck nice and Black ;) then customer bumpers in the long haul with a sealed tank ;) and nice winch. then have some fun with her off road in the quarries out westward. this is just a beginning to keep myself a bit organized and let everyone see there is still newbies out there reviving old comanches and loving them everybit! any input or advice is always appreciated. thanks for keeping the old jeeps alive and kicking and thanks for all the inspiration !!
  10. Id check out the capacitors. if any of them look like a silo. if so then you have blown caps and should think about a new mobo or new machine. also check your ram. if you have multiple sticks take one out at a time. if you replaced the powersupply it probly is not the culprit. 5 years of IT managing :)
  11. Hey there looking for a rear axle for my beasty 88 comanche short bed 4.0 standard. Local to MA preferably. any info is greatly appreciated Thanks
  12. my new to me 88 comanche ^(*o*)^
