MJRemi Posted May 15, 2011 Share Posted May 15, 2011 Sooo... I finally got around to installing some 2" Chevy drop shackles I bought on ebay. Of course they are slightly too big! The top end is too wide (1/4"), the bushings bolt hole is too big ( a lot of wiggle room ), And the bottom of the shackle is about 1/3" too wide for the leaf bushing. :fs1: They supposedly fit a Chevy 1500 from 88 to 07. Does anyone have the exact years or a part number for the correct drop shackles? I need to replace these asap so I can install them when I swap in the D44. :wrench: Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 15, 2011 Share Posted May 15, 2011 You have the correct GM shackles; that's just how they fit. To use them you can compress them down by tightening the reciever end bolts and bending them in :ack: or use washer shims. Either way it's not a correct fit. Spring for a geasable set of shackles specifically made for the MJ/XJ, like these from Teraflex: Link to comment Share on other sites More sharing options...
MJRemi Posted May 15, 2011 Author Share Posted May 15, 2011 Thanks Hornbrod. I'll have to see if I can return these. If not, I'll look into selling them and getting the Teraflex set. Link to comment Share on other sites More sharing options...
kyleag89 Posted May 15, 2011 Share Posted May 15, 2011 When I installed drop shackles on my MJ the top needed to be ground down about 1/8" and the bottom fit perfectly around the leaves. The bolt sleeves were also the correct size. I think you got the wrong pair, Chevy shackles are not the same from 88-07 they changed a couple times. I used a set off a 94 1500 that a local guy sold me off his truck. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 15, 2011 Share Posted May 15, 2011 From what I've read its 88-97 on the shackles Link to comment Share on other sites More sharing options...
MJRemi Posted May 16, 2011 Author Share Posted May 16, 2011 I'll look into the year issue. I thought it was odd the part would be the same for 19 years. 88-07 was hand written on the box in marker. Link to comment Share on other sites More sharing options...
