Are they the same? Since I bought a HO cherokee (still sight unseen, I get it in a month when I'm off tour) and it has a bad serpentine belt, I'm thinking I might as well relocate the alternator to where to AC compressor is normally. I know how to do it on a renix, but I'm not sure if it works on a HO. Unless it turns out the cherokee has AC, in which case I'll probably just use it as a compressor.
Similar? Totally different?
Yeah the same I just pulled a 92 HO compressor bracket bolted up perfectly on the 87 in process adding AC. I doubt they would have change block/head design maybe internally change alittle but externally the same.
I don't think they use the same alternator, so I figured there might be differences.
Anyways, good to know. Thanks. I can continue to plan my insanity.
No but they should mount the same.
