gixxerman600 Posted May 29, 2008 Share Posted May 29, 2008 This was not fun, in the city crossing 4 lains and pow it did not go were i wanted it to go pucker factor x10. :headpop: Link to comment Share on other sites More sharing options...
Geonovast Posted May 29, 2008 Share Posted May 29, 2008 Could've been worse. Could have been a tierod. Duct tape it back together, it'll be fine. Link to comment Share on other sites More sharing options...
pingpong Posted May 29, 2008 Share Posted May 29, 2008 OK we need details... was it stock or after market... where was the break at... the upper side, or the lower side? Link to comment Share on other sites More sharing options...
gixxerman600 Posted May 29, 2008 Author Share Posted May 29, 2008 Its the BDS bar and it broke at the threds on the top side. The worst part is i did not have my sway bar hooked up. :eek: Link to comment Share on other sites More sharing options...
maddzz1 Posted May 29, 2008 Share Posted May 29, 2008 2 weeks ago this happened to comanche87 too. It broke right at the bottom of the threaded part that goes into the bracket where it meets the end. It was stock. We had to get a new bracket because the piece that broke off had rust welded itself in place. We even beat it with a hammer for 2 hrs trying to get it out. Link to comment Share on other sites More sharing options...
pingpong Posted May 29, 2008 Share Posted May 29, 2008 Its the BDS bar and it broke at the threds on the top side. The worst part is i did not have my sway bar hooked up. :eek: I am not familar with their setup, but was the Jamb nut tight (if present)? I have a few stock Bars and brackets laying around if you need one to get by until you get a replacement. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 29, 2008 Share Posted May 29, 2008 Was it the bar itself that broke or was it the end link (heim joint, or TRE)? Link to comment Share on other sites More sharing options...
gixxerman600 Posted May 30, 2008 Author Share Posted May 30, 2008 It was the threded rod patr that is adjustable were the jamnut is to lock it in place. it broke above the jam nut. Link to comment Share on other sites More sharing options...
pingpong Posted May 30, 2008 Share Posted May 30, 2008 So is it just as simple as replacing the joint at the top? Then that isnt too bad :brows: Link to comment Share on other sites More sharing options...
gixxerman600 Posted May 30, 2008 Author Share Posted May 30, 2008 At least with bds its coverd for full life time i break it they replace it Link to comment Share on other sites More sharing options...
Eagle Posted May 31, 2008 Share Posted May 31, 2008 At least with bds its coverd for full life time i break it they replace it Cool -- if you live to tell about it. If you haven't experienced it ... unlike the (anti)sway bar, there is nothing even remotely optional about the track bar. Without it, you have no steering. Link to comment Share on other sites More sharing options...
