Pic of Fan Shroud?
Seems to be a common problem. When I bought my truck it didn't have the bottom on it either. I replaced it when I did the cooling system conversion. They are not expensive...even at the dealership.
K, thanks guys. Would not having that bottom part have a negative effect on the cooling system? What I'm really asking is getting a new one going to actually help keep the engine temp cooler?
The shroud is designed to direct and pull the most air through the rad, so if part of it's missing, you're not getting the best efficiency (such as it is) of the mech fan. So I would say most definitely it effects cooling.
