Jeep Comanche Maintenance Schedule.
Every 250 Miles Or Weekly
Check the Engine Oil Level
Check the Coolant Level
Check Windshield Washer Fluid
Check Brake, and Cluck Fluid Level
Check Tire Pressure.
Every 3000 Miles Or 3 Months
Check Auto Transmission Fluid
Check Power Steering Fluid
Check and service battery
Check The Cooling System
Inspect and Replace all Hoses under hood
Inspect Windshield Wiper Blades
Every 7500 Miles Or 12 Months
Inspect Steering Components
Change Oil And Filter
Lubricate chassis Components
Check Exhaust System.
Check Manual Transmission Fluid*
Check Differential Lubricant Level
Check Transfer Case Lubricant Level
Rotate Tires
Check Brakes
Inspect Fuel system
Check Carburator Choke Operation
Check Throttle Body Operation
Check Engine drive Belts
Check Stater Safety Swith
Keep Spare Tire :roll:
Every 30,000 Miles or 24 Months
Rotate Tires
Check Brakes
Inspect Fuel system
Keep Spare Tire
Check Engine Idle Speed
Replace Fuel Filter
Replace Air Filter
Change all Lubricant ( Transmission, T- Case Ect)
Replace and Repack Wheel Bearings
Replace Spark Plugs
Replace Spark Plug Wires
Replace Wires, Cap, Rotors
Every 82,500 Miles Or 82 Months
Rotate Tires
Check Brakes
Inspect Fuel system
Keep Spare Tire
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace Oxygen Sensor, and Emission Timers
jamminz.gifRemember Its Easy To Be A Truck But Hard To Be A Jeep jamminz.gif
  • 5 weeks later...
  • 9 months later...
