DirtyComanche Posted May 11, 2006 Share Posted May 11, 2006 It only happens when it is warm, well, hot. So it's really annoying to figure out what is doing it. Long as it's cold, it idles fine. Once I've driven it for about a half hour, I put the clutch in and it stalls. With some slight foot manipulation I can keep it alive at stoplights. It was doing this when I was wheeling it too... So, I cleaned the TPS. Doesn't seem to have fixed it. I didn't have time to drive it long enough to see. What else would be a likely problem? The EGR valve? Link to comment Share on other sites More sharing options...
pingpong Posted May 15, 2006 Share Posted May 15, 2006 Check your fuel pressure, sounds like your fuel pump might be going Link to comment Share on other sites More sharing options...
Bounty Hunter Posted May 15, 2006 Share Posted May 15, 2006 The IAC motor controls idle, and is often filthy with carbon buildup. I'd remove the entire throttle body and give it a good bench cleaning with the sensors removed, paying close attention to the IAC passages. Link to comment Share on other sites More sharing options...
87manche Posted May 15, 2006 Share Posted May 15, 2006 Also I'd check the intake manifold for leaks, as it warms up it expands, and a leaky manifol gasket is a major vacuum leak. Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 15, 2006 Author Share Posted May 15, 2006 I'd cleaned the IAC and TPS. Seems I'm too retarded to write both. Anyways, seems it pretty much fixed itself. I just didn't have time to test it. I made certain it wasn't a vacuum leak. I'm going to change the fuel filter because I pulled my filler yesterday and realized there was a lot of crap in the filler neck, so there's probably a lot of crap in the fuel too. But, bottom line is it works alright now. I'm good. Link to comment Share on other sites More sharing options...
