Chico Posted April 22, 2008 Posted April 22, 2008 Noob I am. I already broke one. :wall: How da ya take em off?
SuperWade2 Posted April 22, 2008 Posted April 22, 2008 Noob I am. I already broke one. :wall: How da ya take em off? Probably not the "best" way, but worked for me...Jammed this between the door panel and the crank and gave it a little twist and the crank came right off...
SuperWade2 Posted April 22, 2008 Posted April 22, 2008 Just pull it, straight off. Which is how I broke my first one, these are 20 years old and the plastic (at least on mine) was pretty brittle.
Chico Posted April 22, 2008 Author Posted April 22, 2008 Thanks guys. I wonder why the first one broke when I did that :hmm:
MJ'87 Posted April 23, 2008 Posted April 23, 2008 this method has worked everytime: place the shaft between your middle finger and your ring finger, then firmly plant your foot on the door and pull really hard :D followed by a few of these :mad:
Jeepinmanch Posted April 23, 2008 Posted April 23, 2008 I use vice grip pliers instead of my fingers and the crank just pulls off with some force.
brigarpeon Posted April 23, 2008 Posted April 23, 2008 I just use 2 medium flatblade screwdrivers. Point the blades at each other from opposite sides, twist and lift the handle slightly then pull it off. If it wants to be tight all the way then spray w/ WD-40 and use the screwdrivers to form an X to wedge it off w/ little pressure. Tape the ends of the blades so not to tear up the door panel.
