window crank
I just use 2 medium flatblade screwdrivers. Point the blades at each other from opposite sides, twist and lift the handle slightly then pull it off. If it wants to be tight all the way then spray w/ WD-40 and use the screwdrivers to form an X to wedge it off w/ little pressure.
Tape the ends of the blades so not to tear up the door panel.
