RedBullMJ Posted April 20, 2008 Share Posted April 20, 2008 I built a white MJ "Project Redbull" I regret selling it. It was a great truck. So, I bought this 4cyl 2wd MJ real cheap and I bought a TJ rolling chassis cheap....and installed the 4.0, 3550, 231, D30 and bolt in D44. I had to install a 99 cherokee exhaust manifold, re-drill the driver's side motor mount plate and I need to re-do the cross member. So, this is the result so far.....I changed the front to a waggy style: Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Link to comment Share on other sites More sharing options...
reson46 Posted April 21, 2008 Share Posted April 21, 2008 Timmy!!!! :D Good job. I can't wait to see what else you do to it. Willy Link to comment Share on other sites More sharing options...
RedBullMJ Posted April 22, 2008 Author Share Posted April 22, 2008 You knew it was just a matter of time! Timmy!!!! :D Good job. I can't wait to see what else you do to it. Willy Link to comment Share on other sites More sharing options...
wranglercory Posted April 27, 2008 Share Posted April 27, 2008 Did you just get lucky on the roller chassis or how did you aquire it?? Link to comment Share on other sites More sharing options...
james750 Posted April 27, 2008 Share Posted April 27, 2008 Did any comanches come from factory with waggy xj grill and headlights, are they bolt ons? that waggy xj front clip is sick. What years did the xj have the waggy style? Link to comment Share on other sites More sharing options...
RedBullMJ Posted April 27, 2008 Author Share Posted April 27, 2008 I got lucky on the TJ chassis..... The waggy grill never was a factory option, but they are completely bolt on. Link to comment Share on other sites More sharing options...
