JohnQ Posted April 15, 2008 Share Posted April 15, 2008 I'm having no luck finding a steering column with a column shifter, So I am thinking about converting it to a floor shifter. How hard is it to do? Link to comment Share on other sites More sharing options...
Eagle Posted April 15, 2008 Share Posted April 15, 2008 It's much easier than going the other way. You can get a shifter from any XJ (Cherokee). Keep in mind that different engine/tranny/transfer case combinations use different length control rods under the floor, so ideally you should get the parts from an XJ that has the same engine, tranny and transfer case as your MJ. The floor pan of your truck is already set up with the mounting points, just bolt the pieces in and go. Link to comment Share on other sites More sharing options...
johnj92131 Posted April 15, 2008 Share Posted April 15, 2008 JohnQ, Keep in mind that the column shif automatic has a different bench seat from the floor shift automatic. At least my 91 Comanche with column shift has a full bench seat, without any "notch" on the bench. Does anyone know where Jeep sourced the steering column from? That could give you a whole list of different vehicles to look at for a column shift, besides just a Comanche. I am thinking that certain GM products may have the steering column you need. But have no clue as to which products that might be. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 15, 2008 Share Posted April 15, 2008 My 89 has a column shift and also has the notch in the bench seat. Link to comment Share on other sites More sharing options...
possum Posted April 15, 2008 Share Posted April 15, 2008 I have a steering column from a S-10 in mine. The Jeep steering wheel fits it. Link to comment Share on other sites More sharing options...
deziped Posted April 16, 2008 Share Posted April 16, 2008 They be GM columns in 88-89's. Mine is just like the one in this link:http://elcaminocentral.com/article95.html Link to comment Share on other sites More sharing options...
