rear bumper build up plan?
My plan was to make brackets, bolt them up, then hold the main part of the bumper to them, and tack weld them on. Fit is great..much better than I expected.
I guess you could say that I winged my bumper build :???:
That's how I made mine. :cheers:
I scored a HEAVY steel bumper off some kind of truck for FREE! (guy got them on a Chev S10 with an exo rollcage) that has a class 3 hitch built in. Since I plan to haul trailer with my MJ after the auto 4x4 swap is done (got the trans/tcase in, 3/4 of the underhood wiring harness swapped and a tilt column shift to go in. Drive shaft cut down is tomorrow)
