Clutch Master Cylinder
Looking at buying a replacement one for my MJ I am wondering if there are any upgrades (Like the 96+ newer brake booster thing from XJ's) that I should be aware of before I go out and just get a plain one for my year MJ...
Anyone know of anything?
I was looking into an upgrade for mine after going through several new OEM ones. Learned several things.
#1 ONLY use Castrol GTLMA in them for longevity!
#2 Make sure the clutch arm isn't bent or it will push on an angle against the master and chew up the seals (my son's broke right off before we discovered the issue!)
