maddzz1 Posted April 7, 2008 Posted April 7, 2008 Does anybody know where to get the gaskets for them? or should I just use black RTV? Do I have to use hi-temp paint to paint the valve cover or can I use rustoleum? It says don't use on anything above 200*. But the valve cover doesnt get close to that does it?
jtdesigns Posted April 7, 2008 Posted April 7, 2008 Does anybody know where to get the gaskets for them? or should I just use black RTV? Do I have to use hi-temp paint to paint the valve cover or can I use rustoleum? It says don't use on anything above 200*. But the valve cover doesnt get close to that does it? I just used the black rtv.. I used it lightly on both sides of the reed valve.. I didnt use high temp paint either.. just regular paint.. I did sand blast the vc first then used a die grinder with a tootsie roll to clean up the burs and casting flashing/marks.. Then used some sem acid etch primer on it..roughed it up with some scotch-brite before I painted it.. I did however not have patiences to let the paint cure and got my big thumb prints in the paint when I put the vc back on,,, I guess I'll just have to redo it,,, next summer that is... :D
