maddzz1 Posted April 3, 2008 Share Posted April 3, 2008 How do you repalce the weather stripping along the bottom of the door window on the outside? mine is all dry rotted and starting to break apart; I'm worried about water getting down in my doors. Where can I order it? Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted April 3, 2008 Share Posted April 3, 2008 I just replaced mine from www.teamcherokee.com Link to comment Share on other sites More sharing options...
maddzz1 Posted April 4, 2008 Author Share Posted April 4, 2008 Do you have to take the door apart and take the glass out? This is the only piece of weather strip that the FSM doesant mention Is it the one that says complete wiper set on teamcherokee? Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted April 4, 2008 Share Posted April 4, 2008 Do you have to take the door apart and take the glass out? This is the only piece of weather strip that the FSM doesant mention Is it the one that says complete wiper set on teamcherokee? It is this one http://www.teamgrandwagoneer.com/parts/ ... /1384.html Yes it is expensive 59 bucks because it gives you the interior as well. I didn't have to remove anything used a screw driver gently and off the old one came. Link to comment Share on other sites More sharing options...
maddzz1 Posted April 11, 2008 Author Share Posted April 11, 2008 Did you need to buy the wipe clips too? or could you reuse the old ones. These: http://www.teamgrandwagoneer.com/parts/ ... /1874.html Link to comment Share on other sites More sharing options...
WahooSteeler Posted April 11, 2008 Share Posted April 11, 2008 That's a good price for the whole set, but if you just need 1 or 2 pieces, you can get them here: http://www.trademotion.com/partlocator/ ... atalogid=2 ***fyi..the site is actually wholesalemopar.com, this link is actually through the search software of the site, i.e. trademotion.com is not a parts website you don't have to take the glass out. you might be able to do it w/out removing anything since your replacing the strip and if you tear it up coming out, no big deal. but it's pretty easy to remove the door panel and inner strip which makes it easier to remove and install. this also allows you to inspect your retainer clips to make sure it is being held in tight. a fairly easy job though..... Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted April 11, 2008 Share Posted April 11, 2008 Did you need to buy the wipe clips too? or could you reuse the old ones. These: http://www.teamgrandwagoneer.com/parts/ ... /1874.html I reused the old ones Link to comment Share on other sites More sharing options...
