hey guys iam back my red comanche STILL overheats.. ill tell you what ive done and what it does and hopefully someone knows more than me haha.
ive put a new thermostat in.. iam almost positive the water pump is fine. i flushed the radiator.. and still it overheats
it warms up like normal but when it gets to about 190 the oil pressure starts to go down.. but the oil pressure starts out at 40psi even when cold and goes down...and it will slowly get hotter and hotter even as i drive on a highway..etc and it gets hot fast at redlights..
ive heard about the reverse rotation problem with water pumps..
and someone told me about my catalytic converter maybe clogged? but those are still things i havent tried.
any ideas?
EDIT: i put in a 160 degree thermostat
