702_MJ Posted March 5, 2008 Share Posted March 5, 2008 A trans hose came apart on my truck and i don't know how to fix it. Its a hose that goes to the external trans kooler. It came right out of that crimped sleeve. I need to know what i can do? here's the options i was gonna take..... 1. put a clamp on the crimp sleeve thing and clamp it until its really tight on the hose and see if that works. some ghetto stuff right there. 2. Or if that fails cut right befor the sleeve thing and flare out the tube and then put the hose over it and just clamp it down and pray to the jeep gods it can get me to and from work. Also is there any where i can find just a new line? Link to comment Share on other sites More sharing options...
Wildman Posted March 5, 2008 Share Posted March 5, 2008 OR- 3. Just order new lines or fittings you need- http://www.rockauto.com What ever you try to fix the quick connect lines, they will not last, just replace them and be done with it ;) Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 5, 2008 Share Posted March 5, 2008 OR- 3. Just order new lines or fittings you need- http://www.rockauto.com What ever you try to fix the quick connect lines, they will not last, just replace them and be done with it ;) X2. Here's all the part numbers you need: Pressure Hose 624301 Return Hose 624300 Metal tube 624334 Fittings at Tranny 800714 Link to comment Share on other sites More sharing options...
702_MJ Posted March 6, 2008 Author Share Posted March 6, 2008 thanks man, now its time to order them. Link to comment Share on other sites More sharing options...
702_MJ Posted March 6, 2008 Author Share Posted March 6, 2008 i kinda jerry riged it for now hopefully it lasts just 3 days Link to comment Share on other sites More sharing options...
TNT Posted March 6, 2008 Share Posted March 6, 2008 You can just cut the crips off and replace the hose. Make sure you use hose is for trans fluid. Use fuel injection type clamps so they don't cut into the rubber. As long as the tubes are good there is no reason to replace the whole line. The crimps are done because it is faster in production. If a quick disconnect fails Napa should have them. Link to comment Share on other sites More sharing options...
702_MJ Posted March 8, 2008 Author Share Posted March 8, 2008 yeah i havent checked the local stores yet, its working ok for now Link to comment Share on other sites More sharing options...
