maddzz1 Posted March 3, 2008 Share Posted March 3, 2008 I have always just used the gasket shellack (in the brown bottle). Is it better to use the blue RTV? Link to comment Share on other sites More sharing options...
Wildman Posted March 3, 2008 Share Posted March 3, 2008 If your talking about Indian Head shellac, your dating your self :D Don't ask me how I know :roll: Plus it's only good for 'cork' gaskets, as a placement "glue" not a true sealant, and the rubber compound gaskets are much better in the long run. That's has been, RTV is where it's at, can't be beat for gasket sealant ;) I use Black (Hy-temp) RTV for everything. Link to comment Share on other sites More sharing options...
maddzz1 Posted March 3, 2008 Author Share Posted March 3, 2008 I used it today (the shellac) when I put my new stat in. No leaks so far. With the black rtv do you put it on both sides of the gasket? Link to comment Share on other sites More sharing options...
mvusse Posted March 4, 2008 Share Posted March 4, 2008 My stupid @$$ decided to check out the thermostat 5 miles from home where the gasket was. Black RTV is the only thing I happened to have in the truck, so I used it without a gasket. Black RTV on one side of the housing, put it in place and fasten the bolts. 500 miles and 3 weeks later it's holding up good without any leaks. I think coolant is the *only* thing not leaking on this truck. Link to comment Share on other sites More sharing options...
Wildman Posted March 4, 2008 Share Posted March 4, 2008 Yea, I use the RTV on both sides, first on the "housing" side, set up some to hold the gasket in place, then on the face just at time of install. http://www.partsamerica.com/ProductDeta ... yCode=2132 Been getting it in the pressurized can the last couple times, much better ;) Link to comment Share on other sites More sharing options...
TNT Posted March 4, 2008 Share Posted March 4, 2008 I use 3M super weatherstrip adhesive to hold the gasket to the t-stat outlet and if I would use anything on the other side it would be some grey Mopar RTV. Because of the rough texture on the t-stat outlet I use a very thin coat of the 3M all the way around. If the block cleans up great I won't even seal tht side. The 3M super weatherstrip adhesive also does a good job of holding the thermostat in place when used in a couple spots. I port the T-stat housing on my 4.0 Jeeps. I also use Robertshaw style t-stats for their accurate open and closing control and the fact they increase the amount of flow allowed when fully open. As an ex mopar tech I use the 3M super weatherstrip adhesive(yellow gorilla snot) to hold gaskets in place quite often. It was also used by 90% of the other techs I've worked with. In most cases a few spots of it will hold a gasket in place. It also work good for making sure the gasket stay on the side you want it to if you need to remove that part later. Link to comment Share on other sites More sharing options...
