The lower transmission line connects to the radiator with some hose that has a metal fitting that has a silver collar that is crimped over it and the rubber hose. It is similar to the ones on the lines that run to the heater and the pressure bottle. How do I get it off? I am trying to replace the radiator. Do I need to buy a new one after? can I just buy some hose and use hose clamps? If I buy a new one what tool do I need to crimp the silver metal piece?
Can someone make these click free. Thanks
It should have a threaded fitting that you can unscrew from the radiator. If you have the new radiator on hand you can look where the hose goes in and see if there's a threaded port for it. If you do end up haing to cut the hose you can have a new one made at alot of small parts stores. Some of them will have signs in the window saying "WE MAKE HOSES". The crimp on that metal collar around the hose is done with a hydraulic hose crimping machine.
I added pics. If you look at the second pic, it doesnt unscrew. If I unscrew that nut on the radiator the little elbow piece is part of the rad. It is also like that on the new rad. In the first pic there is also one of those crimped over the hard tranny line.
Can you loosen the nut and the elbow doesn't rotate? If you can, I'll bet you $20 that if you unscrew the nut all the way the elbow will pull straight out of the radiator and you'll be able to reuse it on the new one.
I took the nut all the way off the elbow doent move.
There is a quick - disconnect fitting in the yellow circle below.
Image Not Found
You need a tool like this one from NAPA to slide into the fitting to release it.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=SER&PartNumber=3530&Description=A%2fC+%26+Fuel+Line+Quick+Disconnect+Set
Then that piece will just slide on over the elbow on the new radiator?
Thanks, I was just about to cut the line behind the clamp ans use a hose clamp to attach to the new radiator.
This is why this site rocks. jamminz.gif You can find out how to do things correctly instaed of half-a**. To bad the previous owners didnt know about it.
Yes, you place the correct size tool around the hard line (ID is the same as the hard line), then slide it into the quick disconnect fitting to release the keeper prongs inside. Then the cooling line snap fits onto the new rad hard line, sort of like an air chuck.
Oh, and while at NAPA you should get a quick disconnect repair kit and replace the o-rings inside while it's apart. These things like to leak if they haven't been opened up in years.
I accept cash or money order, no checks. ;)
Thanks for the quick help. Trying to get this done before it drops back to single digit temps.
Alright, Ill proballt post again later to ask how to use the repair kit.
