Ax5 Slave
Looks like I need a Master And Slave Cylinder, Its Internal.
Anyone have any advise on the external Conversion, Maybe a Writeup on it.
Also, a Photo would be great, So's when i order it I know I'm getting the right Part.
(Slave and Throw are the same same in that Trans Right?)
~Thanks in Advance
Ryan
the one on the left looks like an internal setup and the one right is an external based on the image you will need the bell housing for sure to start with which you find at the bone yard the slave its self should be had from a local parts store or let your finger do the walking "discount jeep parts" see what you find there
this links shows the difference
http://www.pirate4x4.com/forum/attachment.php?attachmentid=86384&stc=1&d=1064967859
this image is from off-road
just for starters and keep us posted :cheers:
